fault code on VCDS
kgates Nov 17, 2008
  1. kgates
    kgates 6 in the box
    14
    I am new to the audi seen, but use to own a MK2 golf, mk1v and a mk IV jetta PDTDI. I have just purchased a 2006 A3, and ran VCDS and am having problems figuring out what my electrical problems are on central convience and passenger door.
    Belowe is my last scan.
    Saturday,15,November,2008,08:37:21:62531
    VCDS Version: Release 805.1
    Data version: 20080823
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    VIN: WAUNF78P66A002043 Mileage: 80810km/50213miles
    Address 01: Engine Labels: 06F-907-115-AXX.lbl
    Part No SW: 8P0 907 115 B HW: 8P0 907 115 B
    Component: 2.0l R4/4V TFSI 0080
    Revision: --H10--- Serial number: AUX7Z0E2FNH04O
    Coding: 0103010A18070160
    Shop #: WSC 25101 444 52946
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0021126
    Shop #: WSC 06314 000 00000
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 H HW: 8P0 820 043 H
    Component: KlimavollautomatH14 0180
    Revision: 167903 Serial number: 8P0820043H
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 A HW: 8P0 959 655 A
    Component: Airbag 9.41 H10 3250
    Revision: 91H10325 Serial number: 0035W0000WB/
    Coding: 0032605
    Part No: 8P0 910 339
    Component: BF-Gewichtsens. 01 0020
    Coding: 00032605
    Address 16: Steering wheel Labels: 8P0-953-549.lbl
    Part No SW: 8P0 953 549 C HW: 8P0 953 549 C
    Component: Lenksäulenmodul H21 0050
    Coding: 0002042
    Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0080
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 HW: 8P0 920 981
    Component: KOMBIINSTR. VDO H73 0300
    Revision: D06 Serial number: 2242ED06001791
    Coding: 0004263
    Address 56: Radio Labels: Redir Fail!
    Part No SW: 8P0 035 186 F HW: 8P0 035 186 F
    Component: concert II US H51 0410
    Revision: 02S Serial number: AUZ5Z6E6014277
    Coding: 0001005
    Shop #: WSC 06435 000 00000
    End ---------------------------------------------------------------------
    Saturday,15,November,2008,08:44:46:62531
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
    00-Steering Angle Sensor -- Status: OK 0000
    01-Engine -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    62-Door,Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Coding: 0021126
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
    Component: Bordnetz-SG H35 1102
    Revision: 00H35000 Serial number: 00000001655019
    Coding: E18C5F82C014100000181800180000000028FE375C1100
    Shop #: WSC 06314 000 08192
    Part No: 8P1 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 06314
    Part No: 4E0 910 557
    Component: REGENLICHTSENSORH10 0050
    Coding: 00150573
    Shop #: WSC 06314
    1 Fault Found:
    00984 - Left Tail Light (M4)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 209
    Mileage: 80530 km
    Time Indication: 0
    Date: 2008.11.04
    Time: 12:53:00
    Freeze Frame:
    ON
    Voltage: 14.25 V
    ON
    ON
    OFF
    OFF
    ON
    Coding: 0032605
    Coding: 00032605
    Coding: 0002042
    Coding: 0004263
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 250010530901D8
    Coding: 3D3F0342072102
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D06 Serial number: AUX7Z0E2FNH04O
    Shop #: WSC 00000 000 00000
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0040
    Coding: 0000025
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 144 H
    Component: EPS_ZFLS Kl.7 1502
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 D
    Component: 02 KSG H04 0050
    Coding: 9AC003382D08850FC88F447300
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H02 1301
    Part No: 1K0 907 719 B
    Component: Neigungssensor 004 0003
    Component: IRUE n.mounted
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH03 0180
    Revision: 00002 Serial number: 10000001229904
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 E
    Coding: 0000025
    1 Fault Found:
    00936 - Electric Window Switch in Front Passenger Door (E107).
    008 - Implausible Signal - Intermittent
    Coding: 0001005
    Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 B
    Component: Tuer-SG 010 0030
    Coding: 0001176
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 B
    Coding: 0001176
  2. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    65
    Are you noticing any actual symptoms? For example does the tail light actually work? Have you had any problems with the electric windows?
  3. NHN
    29,343
    1,719
    Yeah have you cleared the scan & seen any repeats of the thrown codes?
  4. kgates
    kgates 6 in the box
    14
    Sorry, changed the tail light, works fine. I havent cleared the codes, I will try that first. Makes sence, new car... tought remembering to keep it simple.
    thanks
