Fault code info ?
paddy
Surrey
Anyone any ideas on these thanks..
I have an aircon problem ( it dosnt work) but other than that all seems to working. tried clearing faults but they return straight away.
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 A HW: 8P0 907 279 A*
Component: Bordnetz-SG 1.0 H30 0501
Revision: 00030000 Serial number: 00000000647973
Coding: 058C4F01A0141000000000000000000000
Shop #: WSC 00000 000 00000
VCID: 3B7168A003E3
Part No: 8P2 955 119 C
Component: Wischer WWS Audi350 0180
Coding: 16711696
Shop #: WSC 00000
4 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
004 - No Signal/Communication - Intermittent
01320 - Control Module for Climatronic (J255)
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
00466 - Control Module for Steering Column Electronics (J527)
Urm have you been fiddling at all mate?
Check your CE board Paddy to see if a connector has come loose mate, as strange all these have come up together.
Anyone know why these codes do not appear on the RossTech list ?
Is it worth asking them ?
Consider the post as you having asked.
The reason these codes are not listed is that they seem pretty self explanatory. "No Signal/Communication - Intermittent" means that there is no signal from the module and that the communications is intermittent - not continuous, not always there. So, there is not much more to add. You have a wiring issue or something is messing with the communications bus by which the modules are trying to talk. Could be a module, could be a coding problem, could be a wiring issue, could be the central electric module has failed. You will have to begin troubleshooting the reasons the old fashioned way. An ohm meter and a wiring diagram is where I would start.
But first, as Nigel asked, did you make any changes?
963
917
