fault code help
mehtaman Mar 12, 2013
  1. mehtaman
    mehtaman Member Team Daytona s tronic saloon
    95
    Hi All,
    I ran a full scan on my car and received a few faults, could someone please take a look at them and let me know what may need fixing...
    Navigation
    Code:
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.lbl
       Part No SW: 8E0 035 192 T    HW: 8E0 035 192 T
       Component: RNS-E HIGH EU   H74 0650
       Revision:      05S
    6 Faults Found:
    00532 - Supply Voltage B+
                002 - Lower Limit Exceeded - Intermittent
    00446 - Function Limitation due to Under-Voltage
    00878 - Connection to Speaker Front Left
                011 - Open Circuit
    00879 - Connection to Speaker Front Right
                011 - Open Circuit
    00857 - CD Changer Unit (R41)
                004 - No Signal/Communication - Intermittent
    02005 - Coding Pin
    Central Conv.
    Code:
    Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
       Part No: 8E0 959 433 CQ
       Component: Komfortgerát T3B    4336
       Subsystem 1 - Part No: 8E2959802F
       Component: Tõrsteuer.FS BRM 0606
       Subsystem 2 - Part No: 8E2959801F
       Component: Tõrsteuer.BF BRM 0606
       Subsystem 3 - Part No: 8E0959801E
       Component: Tõrsteuer.HL BRM 0606
       Subsystem 4 - Part No: 8E0959802E
       Component: Tõrsteuer.HR BRM 0606
    2 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
                35-00 -  -
    00962 - Alarm via. Tilt Sensor
                35-00 -  -
    Radio
    Code:
    Address 56: Radio        Labels: 8E0-035-192-RNSE.lbl
       Revision:      05S
    6 Faults Found:
                011 - Open Circuit
                011 - Open Circuit
    02005 - Coding Pin
    Park Assist
    Code:
    Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
       Part No SW: 8E0 919 283 E    HW: 8E0 919 283 E
       Component: Parkhilfe 8-Kan H06 0010
       Revision: 00H06000
    1 Fault Found:
    01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
    NB: I have ommited some details such as serial numbers and coding IDs.
    Many Thanks!
  2. hades-
    9,481
    646
    check the codes on the wiki
  3. mehtaman
    95
    Thanks Bez101
