Fault code help
Looney May 1, 2011
  1. Looney
    Looney New Member
    Scaned for fault codes after the car went into limp mode the other week for the second time and this it what came up:-
    1 Fault Found:
    000665 - Boost Pressure Regulation: Control Range Not Reached
    P0299 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 16
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2208 /min
    Torque: 288.0 Nm
    Speed: 118.0 km/h
    72.54 %
    Voltage: 14.01 V
    Pressure: 2193.9 mbar
    Pressure: 1704.0 mbar
    Readiness: N/A
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 BM
    Component: A4 Klimaautomat 3233
    Coding: 00000
    Shop #: WSC 00000
    VCID: 6DD45DC10D01
    1 Fault Found:
    00716 - Air recirculation Flap Positioning Motor (V113)
    41-00 - Blocked or No Voltage
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 Q
    Component: Lenksáulenmodul 0701
    Coding: 04012
    Shop #: WSC 06335
    VCID: 418CD1716119
    1 Fault Found:
    02071 - Local Databus
    37-10 - Faulty - Intermittent
    Cleared the codes but the air recirculation just returned after a short play with the control's
    I've had a look around some forums and found away to reset the HVAC by going into the basic settings and changing to 001
    Now the fault code has changed to:-
    00735 - Potentiometer in positioning motor for air recirculation flap (G143)
    09-00 - adaption limit surpassed
    If anyone has any info on any of these faults ie: are they common, how to fix, what part and cost etc, please post and let me know
    Many Thanks
    PS. And where to get cheap parts in the uk from?
  2. NHN
    29,593
    1,782
    Check any boost sensors on the intake side of course & the hvac issues, try testing each feature on the climate & make sure its running when reading it, usually these faults fix themselves & arent an issue
  3. Looney
    Looney New Member
    Thanks for you reply
    Can i test the intake sensors with vcds? and what am i looking for
    in regards to the HVAC, when resetting via the basic settings, there is numbers 12345 and 6. I noticed that numbers 5 and 6 didnt move at all during the test. I think this means a flap or flaps ??? isnt moving at all (can someone confirm this?). 123 and 4 have good movement from about 26 to 220, does that sound normal?
  4. NHN
    29,593
    1,782
    Have you checked in measuring blocks to see if it shows your flaps/sensors names & readings?
