Fault code help needed plz!!!
shaz-raul Jan 23, 2010
  1. shaz-raul
    shaz-raul Member
    87
    Hi guys i have got a fault code 0299, intermittent, boost to turbo is low or somethin like that....
    can anyone tell me wat could possibly be wrong with it??
    also my central locking isnt working with the remote, although it locks fine with the key. it was working fine b4 it went into the garage, but is not working anymore. again any ideas what could be causing this?
    thanks in advance guys
  2. markyzs180
    markyzs180 Member
    543
    copied from the vcds wiki...
    16683/P0299/000665 - Boost Pressure Regulation: Control Range Not Reached
    Possible Symptoms
    • Reduced Power Output
    • Limp Mode
    Possible Causes
    • Hoses/Pipes incorrect connected, disconnected or leaking
    • Charger Pressure Control defective
    Possible Solutions
    • Check Hoses/Pipes to/between Components
    • Check / Clean / Replace Charge Pressure Control
    Special Notes
    • When found in 2.0l TFSI:
      • Check Boost Pressure Control Valve (N249), for cracked rubber diaphragm. A new/optimized Valve is available under Part # 06F-145-710-G (or newer), see TPI 2016331 for details.
    Retrieved from "http://wiki.ross-tech.com/index.php/16683/P0299/000665"
    your key may need re-synching.....lock the car with the key then leave it for 10 minutes, then press unlock on the remote and immdediately open the car with the key, this should resynch it...
  3. shaz-raul
    shaz-raul Member
    87
    cheers mark, will do this as soon as i get my lazy ass outta bed:respekt:
  4. shaz-raul
    shaz-raul Member
    87
    hey mark no joy with it, :sadlike:
  5. shaz-raul
    shaz-raul Member
    87
    i think i was doin it all wrong! got it all sorted now, thanks!
  6. shaz-raul
    shaz-raul Member
    87
    anyone got the schematics for an audi A4 b6? i would like to sort out my boost problem but as ive not really ever had the need to me hands on before i havent ever looked into it. also while im at it i have an air con prob as well, the econ light stays on constantly. i dont have a vag com so dont know wat fault code it could be? any ideas guys?
  7. mattyboyc
    mattyboyc B6 Veteran Audi A4 Audi Avant Owner Group TDi
    1,998
    218
    The air-con could be a number of things but the econ light constantly on is normally either a high presssure sensor or low on gas, mine is doing the same but vag-com threw up the code for high pressure sensor, i'm just waiting on parts
  8. shaz-raul
    shaz-raul Member
    87
    cool, ill get sum1 to have a look as the pressure of the gas, if its low ill regas if not then ill have to find sum1 with a vag-com to see what the fault is
