Fault Code.. Anybody had this before?
RyanS3TT Jan 23, 2010
  1. RyanS3TT
    RyanS3TT Member
    527
    Hello everyone, plugged VAG-Com in today for first time on my car..
    I had this warning..
    Address 01 : Engine
    1 Fault Found:
    00561 - Micture Adaption
    14-10 Adaption Limit (add) Exceeded - Intermittent
    Rediness N/A
    I did a bit of research and got this info.
    Anybody had this error before,
    Does it mean its over or under fueling?
    My car is rather modified, with new turbo, remap, exhaust, decat, hoses etc, and sometimes on the motorway when i accelerate it doesnt seem to grunt as much.
    Anyone think thats this error?
    00561 - Mixture Adaptation
    00561 - Mixture Adaptation: Adaptation Limit (Add) Exceeded
    Possible Symptoms
    • Engine Jolting
    • Increased Fuel Consumption
    • Poor Idling/Jolting
    • Reduced Boost Pressure
    Possible Causes
    • Mass Air Flow Sensor (G70) faulty
    • Fuel Pressure too Low
    • Leaks in Intake Air System and/or Exhaust System
    • Injector(s) faulty (i.e. coked)
    Possible Solutions
    • Refuel Vehicle
    • Check Fuel System Pressure
    • Check Mass Air Flow Sensor (G70)
    • Check Intake Air System and Exhaust System for Leaks
    • Check Injection Quantity
    • Check Injector(s)
    How can I check the fuel pressure system or the MAF?
    or even the injection quantity?
    Thanks all, Ryan
  2. jonny87
    jonny87 Active Member
    1,094
    you can check the maf easy enough, disconnect it and go for a drive, it it drives better your maf is screwed
    i have no idea about how to check the fuelling side of things, someone will be able to tell you though
  3. RyanS3TT
    RyanS3TT Member
    527
    in that case the Maf is fine, however some mornings the idle does bounce, which i thought was the maff?
    When the mafs disconnected my car is almost back to standard that tiny little 150bhp i used to have..
    Ouch.. my car used to be slowww :p
  4. Andrew@A.L.D
    3,877
    617
    You might want to have a look at the fuel pump too?
  5. <tuffty/>
    21,008
    3,770
    With the engine warm and idling, check what block 032 says... they will be the fuel trim values...
    These should be more or less 0.0% for both...
  6. RyanS3TT
    RyanS3TT Member
    527
    Im new to Vag-Com.. How do i do this Tufft? :)
  7. <tuffty/>
    21,008
    3,770
    When in the engine control module (01), go to measuring blocks (08), enter 032 in the first group box and click go...
  8. RyanS3TT
    RyanS3TT Member
    527
    At the risk of sounding stupid..
    With the engine on yes?
    haha :)
  9. <tuffty/>
    21,008
    3,770
    Yes mate... ;)
  10. RyanS3TT
    RyanS3TT Member
    527
    I cannot run anything past 025, as im not registerered, and got very annoyed.. hahaha..
    SO i give up...
    Has anyone got Vagcom in the Bristol Area / North Somerset that could offer me a hand...
    Thanks, Ryan
