Fault code 17936 which fuses?
Discussion in 'VCDS (formerly VAG-COM) forum' started by ssbnreso, Jan 4, 2010.
  1. ssbnreso
    ssbnreso Member
    Nov 28, 2009
    80
    Got this fault code:
    17936/P1528/005416 - Camshaft Timing Adj. Bank1 (N205): Open Circuit
    Possible Symptoms
    • Absence of Engine Torque in lower RPMs
    Possible Causes
    • Fuse(s) faulty
    • Wiring/Connectors from/to Camshaft Timing Adjustment Valve Bank 1 (N205) faulty
    • Camshaft Timing Adjustment Valve Bank 1 (N205) faulty
    Possible Solutions
    • Check Fuse(s)
    • Check Wiring/Connectors from/to Camshaft Timing Adjustment Valve Bank 1 (N205)
    • Check Camshaft Timing Adjustment Valve Bank 1 (N205)
    Does anybody know which fuses it relates too:think:
    Thankyou:meeting:
  2. Advert Guest Advertisement
  3. Cockney Boy
    Cockney Boy Member
    Nov 26, 2007
    481
    There are no fuses associated to this particular fault. What it is saying that another part of the vehicle electrical system could be affecting the fault. Best to check every single one. But i suspect it will be the Camshaft sensor that is intermittent/ Open circuit.
    Can you tell us what your car is?
  4. ssbnreso
    ssbnreso Member
    Nov 28, 2009
    80
    Hi thanks for the reply,
    it's a 1997 A3 1.8 sport (non turbo)
    Thanks again
