Fault code 005913 / P1719
NotNormal May 18, 2013
  1. NotNormal
    NotNormal Active Member Team Nano Grey VCDS Map User Audi S3 quattro s tronic
    332
    66
    Any help / ideas, no fault codes in the engine ecu or anywhere else in the car ?!
  2. Audi Doodah
    Audi Doodah Active Member
    377
    35
    The fault occured two weeks ago. Clear it then scan again after a couple of engine cycles.
  3. NotNormal
    332
    66
    Sorry, i should have explained, the fault happened 4 weeks ago, then i cleared it, it then happened again, took the photo, then its happened 5 or 6 times today, but being lazy i used the older photo ;)
    I wouldn't have posted unless i've exhausted all possible eventualities and option, so i pose the question to the masses :)
    any constructive help anyone ?
  4. Audi Doodah
    377
    35
    No info out there on the code but as it's intermittant and ECU related I would check all the connections the ecu for signs of water ingress, corrosion and integrity
  5. NotNormal
    332
    66
    Any idea on the location of the ecu for the box and the engine ?
  6. Audi Doodah
    377
    35
    Sorry pal, I'm an A4. Try posting in the relevant A6 section and I'm sure you'll get more help there.
  7. NotNormal
    332
    66
    I have posted there already, but thanks for your help
    have a good weekend
  8. christof71
    christof71 Member
    60
    Is the you feel a loss of power while driving ?
  9. NHN
    29,509
    1,764
    Have you enabled anything with vcds at all in the last month or so as I've seen that warning when a feature has been enabled & the system isn't available to work properly or at all, speculative atm.
  10. NotNormal
    332
    66
    sometimes the car does feel alittle flat, but not massively down on power
    no, nothing that's related to engine/gearbox anyway.
    Video in motion, tpms, that's about it
    the tpms I've now turned off again, as my abs control unit doesn't support it fully, I can activate everything but it doesn't let me set the pressure in the mmi
    I'll turn off the video in motion tomorrow, as I can't get it to play DVDs in motion or stationary haha
    is there a way of resetting everything to factory via vcds or on the car ?
    this fault was first logged the day before I picked the car up though - so I'm fairly positive it's not coding related but I'm happy to turn off everything I've changed to check
  11. NHN
    29,509
    1,764
    I wonder if the tpms has caused this then, when did you set tpms?
  12. christof71
    christof71 Member
    60
    Take another picture full screen, see your software number gearbox.
    How is your car, which year and what engine code, what code transmission?
    How do you turn on your TV in mottion?
  13. NotNormal
    332
    66
    I only tired the tpms a couple of weeks ago, but the fault first recorded about 4 weeks ago, before i collected the car, so I don't think it's tpms related
    will do it once I return home
  14. NotNormal
    332
    66
    It wasn't anything related to coding
    Turns out it was an issue related to the fuel system
    Every two seconds after the low fuels pressure code flashed up the gearbox fault was logged
    Then the low fuel pressure fault vanished from the ecu
    The cars had a complete fuel system bar the tank and on fuel pipe as per a TPI from Audi - I've done 1000 + miles and its faultless
    the cars slightly better on fuel and the performance is back
    Tom
    gupsterg likes this.
  15. christof71
    christof71 Member
    60
    Are there any errors in the engine control unit?
  16. gupsterg
    gupsterg Active Member
    348
    Thanks for update ... happy :racer:...
  17. NotNormal
    332
    66
    the error of low fuel pressure only came on until the ignition was switched off - then it was gone from the memory when I checked with vcds
    it wasn't until just before we got to the bottom of it the code stayed in the ecu for a longer time
    indeed, very happy motoring :D
  18. christof71
    christof71 Member
    60
    car need check for update ,engine ECU and gear-box ECU.
    I need your engine ECU number and software number.
    Perhaps I have the software, I have to check and compare these with your ECU
