Fat 5's are on!
Geeman Nov 7, 2009
  1. Geeman
    Geeman Low Life
    1,318
    Sad that the BBS's have gone, but these bad boys create much more of an impact!
  2. manzi
    manzi Member
    64
    i'm loving them geeman :thumbsup:
  3. Six-speed
    Six-speed New Member
    27
    Nice! Are they 19s?
  4. Bong Water
    Bong Water In two minds
    786
    They look awesome
  5. 205man
    205man Active Member
    1,072
    14
    oh yes im liking those.........where did you get them from and what size are you running?
  6. phoenixv6quattro
    phoenixv6quattro staylowmovefast
    1,396
    Ha Ha very nice buddy! Looks like all that effort was worth it! How wide are the rims,tyres and are you running spacers? Looks pretty close to the arch on the rear! Whats the offset? Got mine on some spacers now (15mm front/20mm rear)They are actually on the limit of the arch! Offset is 28 rear/33 front.
  7. PaulJC84
    PaulJC84 Owner
    2,914
    17
    Looks awesome!
  8. aragorn
    18,490
    855
    They do look awesome, but the tyres ARE too narrow :(
    From the pics it looks like you've got a lot of camber on the rear? Is that just a trick of the angle? If you do have a lot of camber on the rear then theres something wrong with the axle!
  9. RS_Rawli
    RS_Rawli Member
    55
    perfect
  10. Geeman
    Geeman Low Life
    1,318
    Aragorn... no camber on the rears... look at the last shot - perfecetly straight! Granted, the tyres may be 5/10mm too narrow, but that's what they arrived with, so running them till I decide which size to go for.
    RS Rawli / Soupie / 205man / Bong / 6-speed / MAnzi - cheers for the nice comments guys.
    Ollie... yeah, eventually the wheels I really wanted! They are 8.5x18" ET 45 - still just running the 10mm hubcentric spacers on the rear with nothing up front. The tyres are 215/35's all round - slightly wrong width with these rims and wrong profile I think, but they seem to work well at the moment. I could pop a 15mm spacer on the rear with the existing tyres, but then the wheel would be sticking out... not quite what I'm after. Might put a 5mm up front and see how that sits.
  11. dsmclark40v
    dsmclark40v Member
    744
    theres something familar about them but can't quite put my finger on it...
    they say imitation is the greatest form of flattery :moa: haha just kidding they look great. your car looks alot tidier than mine
  12. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    MAN THAT LOOKS SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET
    :hubbahubba::hubbahubba::hubbahubba::respekt: :respekt: :respekt::hubbahubba::hubbahubba::hubbahubba:
    NICE SHOTS :photo:
  13. Geeman
    Geeman Low Life
    1,318
    It's your fault I've got them... as yours looked so good with them on! :o.k:
  14. Foxmeister
    Foxmeister Fired Up!
    1,785
    Why does all the negativaty start when somebody decides on a set of wheels for their car??? Noticed it a bit here, at the end of the day, these cars are designed to run standard "16 wheels etc so to fit "18 with narrower tyres doesnt mean its wrong, either its needed for clearance purposes or other reasons but either way Audi never designed a B5 to run "18 wheels with specific size tyres!!! Personally, i think they look great Geeman, look smart and fit for purpose i.e modding a car to fit non standard size wheels that dont rub etc. And there doesnt look like any camber issues with them. Seen plenty of cars with severe camber and this looks very tame compared, at end of day, wot modding is all about, personal taste!
  15. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    B5 RS4 did.
    but I agree, they look great. from a distance they look like 19" but it is just the tyre profile.
    what is the ride like on them?
  16. aragorn
    18,490
    855
    The reason i said they're too narrow is becuase the tyres are stretched inwards, with the wheel rim extremely exposed and the tyre sidewall at a huge angle.
    Tyres arent designed to operate in conditions like that, and will not be performing anywhere near their best, not to mention the rim and sidewall being extremely exposed to damage from the pristine roads in this country.
    I asked about camber becuase one of the pics looked a bit odd, but i suspect its just the angle its taken at.
    In my opinion, modifications should be done with function first and form second. Plenty of people run 18" wheels with tyres that fit correctly so its not impossible to achieve. Theres no point doing something to the car if the car then doesnt work properly afterwards. I could fit some 22" chromes and remove the springs to make it look "pure amazing" but if it then wont drive or i cant steer whats the point...
    As geeman pointed out, they're still fitted with the tyres that they came with, so hes not made any active choice to fit those, which is fair enough.
    Personally, i'd be looking to try and ditch some of the spacing on the rear, and run a 235 tyre on there, but having not seen the car i dont know how much clearance there is to do that.
  17. need_more_speed
    need_more_speed New Member
    AWWWWW they are phat! loving them
  18. Oranoco
    Oranoco Well-Known Member
    3,972
    405
    They look superb :thumbsup:
  19. joss
    joss Member
    214
    looks feckin cool as dude..
  20. Foxmeister
    1,785
    Touche my good man:whip:
    But different cirumstances:moa:
    All in all, tyres could be a bit wider but im sure will perform almost as good bearing in mind u avoid standard potholes which are fitted to most uk roads:jester:
  21. Geeman
    Geeman Low Life
    1,318
    I just got proper stuck. The belly was on the floor, and the front wheels were not.
    Pooping it down with rain, blocking the entrance to the church (christening)... ended up having to jack the car up, place things under the front wheel and back off the offending manhole cover/sunken drain. Got proper soaked while everyone just sat there and watched me.
    Made a right mess of the drain cover... think I may have dented something underneath too. The vicar even mentioned me in the sermon as they had to delay the service by ten minutes while I unblocked the entrance! :redface:
    Raise the car up to stop this happening again...? Naaaah! lol
    Air-ride sounds inviting now...
  22. Markey
    Markey Active Member
    2,175
    Very Nice!
  23. need_more_speed
    lol, even god would wait for a audi!
  24. Oranoco
    3,972
    405
    pmsl, well it would seem he had to on this occasion. :nyah:
  25. dsmclark40v
    dsmclark40v Member
    744
    I'll happly take the blame for that... they do look really good on silver a4's
  26. phoenixv6quattro
    1,396
    Fu**ing hell buddy!!! What a predicament to be in!!! Those jack buggers, someone could have helped you. Car is shaping up to be a diamond. Keep it up! (Excuse the pun!).
  27. GforceA4
    GforceA4 Member
    111
    it looks the bolloxs mate, i hope mine will look as gd as ur mate
  28. DJM1982
    DJM1982 Member
    394
    Oooooooooooo, they are very very nice.
  29. Lee Goodall
    Lee Goodall Active Member
    2,279
    Looks brilliant mate!
  30. Lyons
    Lyons Member
    125
    Lovely.
    Whats the proper name for them?
  31. Rallyman
    Rallyman LPG Abuser & have VAGCOM Bronze Supporter
    213
    Nice looks like a mini/shrunken A8...... :D
  32. Broken Byzan
    13,237
    465
    Although i don't subscribe to the Dub theme, slammed on it's **** etc. I do have to say that she does look good mate.
    :icon_thumright:
  33. floyd 1.8 turbo
    floyd 1.8 turbo Mirror, Signal, Outmanoeuvre
    632
    Love it Geeman, looks sweet.
    Thats how i'm gonna have mine, right on the floor with tyres that look like rubber bands!!!!........just how i like em
    Well done
  34. joss
    joss Member
    214
    same thing happend to me on one of those one way toothed speed hump things..drove over it only to hear a clunk and get wedged propper solid on top of it..took me half an hour to get of it..didn't make me raise the beatch up though..
