Faster, Slower or just the same?
Beerzo Aug 8, 2006
  1. Beerzo
    Beerzo Masa'warty 3200... Talk To Me!
    1,242
    If you take an empty bottle and place the open top under a running tap from a distance of 1 inch. Assuming you can move the bottle down from the tap any given distance, althought the water running into the bottle remains constant. Will it take the bottle longer to fill when its further from the tap than what it would it if was an 1 inch from the tap? :readit:
  2. nervus
    nervus Well-Known Member
    1,370
    120
    Assuming there is a constant stream flow the bottle moved down away from the tap will fill quicker as the velocity of the falling water will increase as it falls - surely?
  3. Beerzo
    1,242
    Its a good one, but surley the closer to the tap the less it has to travel?
  4. Geordie Mike
    Geordie Mike Yeee-haw
    520
    When do you start the clock? When the water passes through the top of the bottle?
    I guess it depends on the supply pressure of the water really.
  5. Beerzo
    1,242
    I would say you start the clock as soon the bottle is placed under the water.
  6. nervus
    1,370
    120
    But if there is constant flow the water has already travelled to the point of fill when you place the bottle in the stream so that time has already passed and not added to the fill time!
    If you had 1 litre of water only delivered through the tap and you had to fill a 1 litre bottle then both times would be exactly the same assuming there was a small gap between the bottle and tap. If not then flow rate/ vs fall velocity would have to be calculated.
  7. Beerzo
    1,242
    Its so annoying i have been trying to test this at the water fountain in my work for weeks now. I only have a distance of 4 inchs to test this though. When i say test i realy mean something to ammuse me while my bottle is filling up. I seem to have developed an OCD for this.
    I would think that the closer to the tap it should fill quicker but then if the flow is constant it would not matter if you moved the bottle a mile below the tap the water flowing into it would be the same, would it not?
  8. Geordie Mike
    520
    From what I remember from school/uni this will come down to a terminal velocity kind of thing - if the water is falling below terminal velocity out of the tap, it will be the same no matter what, as you need the same volume to fill the bottle and that rate (in ml/sec or whatever) is coming from the tap - it's controlled by the pressure drop across the spigot.
    If your water pressure is really high and coming out above terminal velocity so that it is slowed down by friction then as the water were to fall e.g. 100 ft I think it would slow down and be a little slower. This might be nulled by the fact that you have steady state conditions as you are setting the tap running and then putting the bottle under, so it comes back to the rate thing. Water at that pressure would piss everywhere though I think.
  9. jojo
    28,846
    3,509
    In my Humble opinion, I will take the same time to fill. :lick:
  10. Geordie Mike
    520
    I'm offshore right now - I'll see if I can line up a fire pump off the helideck and try filling barrels - will give me something to do while I wait for the chopper!
  11. Beerzo
    1,242
    But water falling over a certain height becomes a mist quite quickly does it not? But i get what you mean the water will accelerate till it becomes mist then it will slow down again. I think! :wtf:
  12. Geordie Mike
    520
    I think that's more the nozzle that determines that - you just need a bigger outlet if you want to keep it together before you reach critical flow. Think about a garden hose setting/pressure washer.
  13. Beerzo
    1,242
    ROTFL :laugh:
  14. Geordie Mike
    520
    And the answer is you get too wet timing it to care...
  15. arthurfuxake
    1,308
    The water exits the tap at a constant flow rate which is measured in volume per hour. So, if you have a 1 litre bottle, and the water is being pumped at 1 litre per hour, it will take you an hour to fill the bottle. There will be no time difference if the water is already flowing when you put the bottle beneath the tap. If you first put the bottle under the tap, and then start the water flow, there will be a time difference relative to the distance covered by the water from the tap. If the bottle is 1 inch from the tap, the water takes x seconds to travel that 1 inch. If the bottle is 10 inches from the tap, the water takes y seconds to travel 10 inches. As 10 inches is bigger than 1 inch, y will be bigger than x. QED.
  16. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    it will take the same time whether it was 1 inch or 1 mile away, the volume of water from an open tap will remain the same, the speed makes no difference, its the volume that determines the fill rate not the speed in which it is presented.
    the only problem you would have would be the dispersal of water over distance, the further it falls the more the surrounding air affects it and the more it would disperse.
  17. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator Team V6 TFSI Owners Group Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,116
    2,571
    You really don't have enough work to do, do you?
  18. silver75
    silver75 Big Ron
    3,265
    what he said :end_of_discction:
  19. fallmonk
    fallmonk Turbo Sport
    1,868
    MMMMMMMMMMMMMMMMMMMMM
    This looks like another "Would the plane take off? " thread !!!!!!!!!!!!!!!
    Personaly i think if the bottle was closser it would fill quicker ,thats only IF your time(ing) from bottle is under tap, NOW if your time(ing) from the moment water hits the bottle lip it would be the same!
  20. Geordie Mike
    520
    No one mentioned the bottle was on a plane. Do you think that would make a difference?
    Mike
  21. Caesium
    4,879
    oh dear...
  22. silver75
    silver75 Big Ron
    3,265
    depends on if its still on the runway or if has taken off but it doesnt make a difference because of the velocity or something
  23. Caesium
    4,879
    how about if the plane was in a steep dive, then the water would float out of the bottle and all over the cabin, or if it was milk it would smell all nasty after a while, or if it was cranberry juice it would stain your clothes, but at least you can swim through cranberries, and you cant swim through pineapples
  24. Caesium
    4,879
    that avatar is pure class!
  25. Geordie Mike
    520
    I don't think a pineapple would fit through the bottle neck.
  26. bainsyboy
    bainsyboy Guest
    Any way im going to look for the airoplane conveyor belt thread for a bit more excitement
