fast road cat cam audi s3 good mod
cheflloydy Feb 19, 2014
  1. cheflloydy
    cheflloydy New Member
    is it worth putting fast road cat cam (cam shaft) on my s3.
    it currently has twintercooler. remape revo stage 2 +. apr fuel pump, v flow induction kit. forge dv recirculating, miltech full exhaust. currently pushing out 309 bhp on dino.
    will a fast road cat cam be a good mod????
  2. XFi
    XFi In need of a V8.
    491
    47
    For the cost of cams you don't gain much on a turbo car.
  3. cheflloydy
    cool. been reading up on them and they say its a easy mod with great BHP gains. they didn t mention none turbo only. suppose it makes sense.
  4. sje00
    sje00 Member
    The right cam's can transform a cars power delivery!
  5. nil538
    nil538 Active Member
    492
    66
    Are you sure your only pushing out 309bhp at revo stage 2+ ? Should be around the 360ish mark
  6. S3Alex
    10,469
    4,521
    Frankly,on a Stg2+ car,the answer is going to be no.
    The main sticking point on the car at that level is the stock turbo,which is pretty much finished at 360-380bhp,which is what your car should be producing right now.
    The other point will be the extra lift and duration of the new cams,and whether or not that will clear the stock pistons.
    If you have a big turbo conversion,and want over 600bhp,having done ALL of the other things you need to,including the correct pistons and rods,head and valve work,then it would be worthwhile,but on a stock head,mine is already turning out around 500bhp.
    The point there is that the stock head and cams are pretty good,and you would need to be looking at a lot of work to make a set of those cams worthwhile.
  7. cheflloydy
    thanks alex. has cleared a lot up. whats have you done to your s3 to make it deliver near that 500bhp
    S3Alex likes this.
  8. S3Alex
    10,469
    4,521
    Here's the build thread.
    http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/106134-time-build-thread-big-turbo.html
    A LOT of hard work from AMDTuning,making it all work and deliver reliably for a daily driver,and a fair bit of cash.
    In short....
    Suspension rebuild.
    Uprated brakes.
    Engine rebuild.
    ATP big turbo kit.
    Owen Developments GTX3076.
    Uprated LP and HP fuel systems.
    Exhaust mods.
    WMI
    Revo Stg4 software.
    And a bit more to come shortly.
