FAO S3Gazz your AGU head
Andrew@A.L.D Feb 20, 2012
  1. Andrew@A.L.D
    3,872
    608
    Pictures don't it any justice as its just a mobile phone camera
    Just have to finish off the inlet ports then its off to the machine shop for new guides and seats recut
  2. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Oh my god that look sexual?!
  3. Andrew@A.L.D
    3,872
    608
  4. jojo
    jojo Looking for Boost! Staff Member Moderator Team Daytona quattro Audi S3 Audi A6 Audi Avant Owner Group
    28,819
    3,478
    Shame it's going to be wasted going into an S3 huh? :laugh:
  5. Broken Byzan
    13,235
    464
    I'd be worried it's too big and will alter the velocity of the air.
    Shiney though
  6. Andrew@A.L.D
    3,872
    608
    The inlets have only been cleaned up and polished ( not ported ) there big enough
    Exhaust side is a different story :eyebrows:
  7. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    Thanks andrew pics look great I'll ring u Saturday mate
    All good then so for looks it from what it was like to now mint mate thanks cannot wait to get it on now
  8. Andrew@A.L.D
    3,872
    608
    Shame it does't look like that any more
    The face of the head has been attacked with a carbide burr to see the damaged/weather it can be repaired and welded, its worse than the picture as the valve snapped off and rattled round the bore before making its home in the head face.
    Thats just the start of the damage been done and only some of the valve that have been bent/snapped/damaged
  9. s3gazz
    1,376
    99
    Andrew thanks pal do u think ill need a new head then no point in wasting your time if u don't think it will repair mate
  10. Gops
    3,188
    647
    Wow it's so beautiful..
  11. s3gazz
    1,376
    99
    Was beautiful gops ha
  12. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    195
    Oh ****! What happened?
    pSean
  13. Andrew@A.L.D
    3,872
    608
    It can be repaired
    I've repaired heads MUCH worse that yours
    I repaired a RS2000 16v maxi rally car head last year that has major det problem and had a mashed up compression chamber. With a little CNC work and my handy work its now up and running pumping out 255bhp N/A power
  14. Andrew@A.L.D
    3,872
    608
    Wrong length bolt fitted to the crank timing pulley, engine was cranked over, the bolt got jammed shocking the engine to a sudden stop making the timing belt jump bending/snapping loads of valves, damaged the combustion chamber, valve guides, pistons and gazz's pride
  15. s3gazz
    1,376
    99
    Thanks Andrew that's good then tar. Me been a tool pal has cost me lots of money never again tho beware guys somate so small and easy can do so much damage arghhhh
  16. Gops
    3,188
    647
    In Andrews hands, it's defo still beautiful! Damn I need to get an agu head now.
  17. badger5
    9,305
    1,885
    leave engine building to those who know what they are doing...
    think you are saving yourself money "having a go" yourself........... Beware
    It costs you far more in the end
  18. s3gazz
    1,376
    99
    i done good putting the engine back together lol to say never touched one in my life and no problems for months was just a stupid mistake lol also help s3dave with his too this my 3rd time now luv doing it my hobby ha
  19. Andrew@A.L.D
    3,872
    608
  20. Scullies
    Scullies Well-Known Member
    1,543
    656
    So this happened on the first start? Did the crank/block also get damaged?
  21. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    How does anyone learn anything with that attitude?
    I guess you was born with all the knowledge and know how of engines, turbos and tuning?
  22. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    Andrew i take it you mean the 4 bolts that hold the aux belt pulley to the crank spocket? if so oh **** the ones i got from TPS are longer than my standard ones, looks like im gonna be cutting them down lol
  23. phil miller
    1,211
    166
    And the penny has dropped, the worlds a small place, did you get your Rings today dude?
  24. Scullies
    1,543
    656
    surely once you have assembled the engine, you would notice something "catching" when you turn the engine over by hand.
  25. s3gazz
    1,376
    99
    ye pal this happened just by turning her over once mad what damage it courses pal
  26. s3gazz
    1,376
    99
    get them cut pal mine was only one and was about 3mm ish bigger and cost me alot of money ha don't make my mistake phil
  27. s3gazz
    1,376
    99
    what happened Scillies is engine been running fine for months after build but one of those nuts worked loose so got another nut not measuring deeer lol and just screwed it in turned her over and heard cracking did not fire. Then took nut out to find smashed crank housing and that cog thing for trimming missing all it teeth nearly oooops
    phil yes pal top guy thanks so much pal
  28. Andrew@A.L.D
    3,872
    608
    I now know why its smokes, Its was nothing to do with the oil seals, gazz said it was more white smoke with a hint of blue?
    Well the head was warped so there was leakage between all cylinders, it needed a few passes to get the head flat and true.
  29. badger5
    9,305
    1,885
    not skimmed previously or happened since gaz fitted it?
  30. Andrew@A.L.D
    3,872
    608
    Happened since gazz fitted it, looks like it over heated at some point. Maybe during bleeding of the rad?
    Every head i do gets a skim unless i'm told not to but alway advice to get it done.
  31. superkarl
    superkarl MAN OF STEEL
    9,321
    2,328
    My confidence in building my engine is diminishing by the day
  32. Andrew@A.L.D
    3,872
    608
    I'm sure you will be fine Karl, Gazz has made lots of mistakes with his build.
  33. s3gazz
    1,376
    99
    I don't get it one car never over heated I'm not going to lie about it 2 never got dropped 3 temp never went above 90 somate else to it
  34. s3gazz
    1,376
    99
    Andrew I don't think it was skimmed before pal as remember when the head surface had marks on it and I asked u if it skimmed shunt mark all of gone got some pics if that helps. If my car over heated I'd ask for help guys bills knows this thanks pal
  35. Andrew@A.L.D
    3,872
    608
    It was skimmed, Every time i had your head it was skimmed.
    The marks in the head was corrosion and nothing to do with the firing ring, Yours was warped across the cylinders causing leaks between the cylinders. The machine doest lie and you can see it when been skimmed.
  36. s3gazz
    1,376
    99
    Collected thanks for the time and effort Andrew pal
