Fan washer jet heads
KKM Jul 8, 2009
  1. southylad
    southylad Active Member
    544
    I would pop round for a full scan now mate if you we're round here I have a cheap eBay scanner but they don't go deep enough eh it picked up the over boost codes when my turbo Gaines were sticking tho so not a total waste of cash eh
  2. mike foster
    3,967
    PM me !
  3. southylad
    544
    Like I say mate you and most on here are about 2 hours drive away from me and I am at work 6 days a week, so that's the problem otherwise I would be bothering you all the time there are loads of little tweaks possible on the vcd's eh
  4. grr666
    grr666 Member
    171
    19
  5. MTRL
    MTRL Split Grill!
    459
    52
    Let us know how you get on with them. Ill add to my list for payday
  6. shariain
    shariain Well-Known Member
    1,183
    192
    Might get this done myself
  7. southylad
    544
    So these def fit my 56 plate a3 cos its not on his list
  8. NHN
    29,593
    1,782
    The fan washer jets fit all A3 8P's & the part number superseded ages ago to the C variant as mentioned here.
    They're heated, but they will still fit spray wise if yours arent heated originally, also you may have to extend one of the heated jets looms as mine required this to be able to plugin.
    The plenum chamber cover where the jets fit was modified by audi at some point & actually has a slight raised area where the jets sit, thus holding them in tighter as they do seem a tiny bit loose on the older cover, they wont pop out, just a little loose overall.
    Funny thing is, the part number for the cover never changed which is strange for audi, as all parts that were modifed or changed manufacturer had a part number change.
    So I bought a newer one to make sure they stood fast in there holes.
  9. ryanstewart9
    ryanstewart9 Member
    494
    Just ordered a set for mine.
    Thanks JS3 & NHN :)
  10. Artimus
    Artimus Shortback
    2,017
    487
    aaah ****, another must have minor mod ...does it ever stop?
    Ordered, thanks guys.
  11. southylad
    544
    Ordered mine I do miss them from my old passat cheers for info grr666 , js3' and NHN
  12. southylad
    544
    Just fitted my fan washers and I did have to extend the near side wiring as it was a bit short as the plug is on the other side wasn't to bad to do just a bit diddly and bloody cold on the fingers they need ajustng tho as they are spraying a bit high do you undo the little Allen bolt to adjust them?
    Artimus likes this.
  13. grr666
    grr666 Member
    171
    19
    I reckon so having looked at the inside of them, mine are here but sod going out there to do 'em while it's this cold.
    I'm not even sure if mine are heated tbh. But a bit of solder and heatshrink will do the job
    if mine actually are and need extending. Did yours clip in ok southylad?
  14. Acheron
    Acheron Active Member
    271
    30
    Sigh. :no:
    *adds to cart*
  15. southylad
    544
    Not exactly the same fit as original jets mate but they clip in ok and working fine and the heater wires are just a bit fiddly to extend but got it sorted ok
  16. ryanstewart9
    ryanstewart9 Member
    494
    Got mine & fitted them today :)
    No need to extend anything on mine as they were a straight swap, & they seat properly too :)
    Not overly impressed with the spray pattern, but I think a little more fine tuning is required.
  17. ryanstewart9
    ryanstewart9 Member
    494
    Not that I'm complaining, but bit confused when his eBay location says Halifax and the items were posted from Poland :)
  18. Artimus
    Artimus Shortback
    2,017
    487
    got mine today but too :cold: to go out fitting. lol
    re the spray pattern\angle: is that an allen key grub screw I see beside the nozzle & is it for adjustment of said pattern or just the angle?
  19. southylad
    544
    It adjusts the angle mate not the pattern i need to lower mine but i could not feel my fingers sunday so will have another look next week
    Artimus likes this.
  20. Artimus
    Artimus Shortback
    2,017
    487
    thanks for the reply! I'll be sure to have the right size key handy when I get a chance to do the job. :icon_thumright:
  21. southylad
    544
    they must have been a bit more generouse with the wires on the facelift mate eh
  22. grr666
    grr666 Member
    171
    19
    He's obviously a middle man, plenty of those on Ebay. He's probably getting them for way
    less than we are but I'm happy with the price so hey ho.
  23. grr666
    grr666 Member
    171
    19
    What reg is yours Southylad? Mines an 09 but the other guy who said his
    wires were long enough has an 08 according to his sig?
    I'm confused dot com :/
  24. grr666
    grr666 Member
    171
    19
    Are yours heated then Ryan?, and your wires just fitted or did you just connect the nozzles?
  25. ryanstewart9
    ryanstewart9 Member
    494
    Yep, mine are heated :)
    My car is a pre-facelift, but right near the end of the line. Both my original nozzles have the heated plug on the same side like the new ones, so no need to stretch any cable. I can only guess at some point Audi changed the design & the way they put the nozzles in (i.e. one part for both instead of a different part number for o/s & n/s).
    grr666 likes this.
  26. ryanstewart9
    ryanstewart9 Member
    494
    oh yeah, I used a small Torx bit to adjust mine :)
  27. southylad
    544
    Mine is a 56 plate s line mate
  28. Artimus
    Artimus Shortback
    2,017
    487
    Did mine yesterday afternoon, but didn't have the time to adjust them as I had to go out, but I didn't need to make any mods to either connector wiring & they're a good, tight fit... MY09
  29. grr666
    grr666 Member
    171
    19
    Yay!! Mine is 09reg too, I may go out and do them today. How long did it take and what tools were required? Any tips to ease the fitting process?
  30. ryanstewart9
    ryanstewart9 Member
    494
    10 mins.
    No tools needed, they should just pop out :)
    grr666 likes this.
  31. A19quattro
    A19quattro Active Member
    663
    102
    43
    I had fan jets on my old Golf and really liked them so may give this a try, anyone got any pictures of the actual jets fitted, before/after would be good?
  32. Artimus
    Artimus Shortback
    2,017
    487
    I used a palette knife to lift an edge, then they just plucked out.
    Tip: don't try to take the black retaining clip off completely, slide it back until it stops & the washer head will pull out of the connector without resistance.
    grr666 likes this.
  33. Jameze
    Jameze James
    523
    85
    Is it me or are these just not that good?
    I ordered a set a couple of weeks ago and have just got around to using them today but they don't seem to live up to the hype.
    I used them a couple of times on the motorway and they didn't really help with wiping off the salt covering the windscreen, whereas my previously installed triple spray washers did the job nicely as they soaked the windscreen. I found myself having to spray the windows for a good 5seconds at least just to get the windscreen wet enough? And even then the wipers couldn't really clear it.
  34. NHN
    29,593
    1,782
    Personally I think they're very good, I think the water spray is finer which may require more prelonged use, but overall they do a better job, positioning is key aswell I'm finding, bit more accuracy for these, as adjusted few times, now just need a small adjustment & will be perfect.
  35. Jameze
    Jameze James
    523
    85
    I wondered about that... When I installed mine they fit perfectly, cable didn't require extending, and when I test squirted them they didn't seem to need adjusting (I was expecting to have to - even had tools at the ready).
    The spray, unadjusted, reached the top of the windscreen and seemed to cover it all so didn't bother adjusting it as it already seemed okay. Did yours have similar coverage when you first installed them? Tempted to adjust them anyway and see if it helps.
  36. NHN
    29,593
    1,782
    I dont have them spraying right a the top tbh, mine wernt good position in the beginning anyway, so adjusted, have a play with them & see what suits you best mate, got on 2 cars & they are better imho.
  37. Jameze
    Jameze James
    523
    85
    I'll give them a play and see if adjusting them up or down helps (may do one on each and compare results). Cheers Nige.
  38. Artimus
    Artimus Shortback
    2,017
    487
    I think they need adjusting down mate.
    I have mine set very low in the housing, almost at the lowest possible, with maybe a millimeter gap underneath! I'm sure one even catches a wiper arm before it moves! I found that with them set any higher, a lot of the spray was going over the roof & off the sides of the screen.
  39. NHN
    29,593
    1,782
    I agree, to high & its like skunk ******* from under your plenum chamber area lmao
  40. southylad
    544
    you dont want them spraying the top mate i have them about centre as when driving the water will creep up not down really
