Fan washer jet heads
KKM Jul 8, 2009
  1. N8
    17,160
    718
    Good find lad.
  2. N8
    17,160
    718
    Just ordered a set :superman:
  3. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    You won't be disappointed mate :thumbsup:
  4. N8
    17,160
    718
    I know Leon, nice little mod! As you can tell, I love modding :)
  5. tdisportuk
    tdisportuk Member
    460
    £11.89 tps trade price inc vat not bad hey!
  6. NHN
    29,650
    1,799
    It would seem the plenum chamber cover/window trim these go into may have a slight modification by audi even though the part number hasnt changed, checked with Matt's & mine & he seems to have a raised area of 0.5-1mm where the jet sits where as mine doesnt, so will confirm with pic from him cause on mine they do move slightly where as on his they dont budge, strange as any modded part from audi usually has a superseded part number.
    But anyway they do still fit, just maybe on older 8P's you need to fix them in place with some sealant as I have on one & possibly need to extend one of the heated jets wires, easy enough done, cut, join/solder & ur away
  7. Staz
    6,206
    67
    I see. I forgot to check mine by the way.
  8. N8
    17,160
    718
    Mine are on, and they're great :)
  9. NHN
    29,650
    1,799
    So is your double post sheepy
  10. Staz
    6,206
    67
    You didn't hang about! :applaus:
  11. N8
    17,160
    718
    Double Post?
    Makes a change :laugh:
  12. Staz
    6,206
    67
    I deleted it already :icon_thumright:
  13. drsilviuro
    drsilviuro Member
    121
    So anybody knows what part number is the cover for the good washer heads? My ETKA shows 8P1 819 415 E 01C. This is for lhd, for rhd is with F instead of E.
    I fitted today the washer heads and had to glue them in place... It would be nice to not use glue :)
  14. Smoothie
    Smoothie Active Member
    1,431
    Nigel, Nate and Staz you guys still have these fitted? Thinking about doing it
  15. N16KSH
    N16KSH Member
    80
    think these would fit on my late 54plate .... after fan type if so any idea on part number of if they is any on ebay ????
  16. jb0o
    jb0o North East Forum Moderator Site Sponsor Regional Rep VCDS Map User
    2,664
    118
    Yes will fit, and part number as mentioned in this thread: 5MO 955 986 9B9 (from a Passat)
  17. Staz
    6,206
    67
    Yep still fitted and they're still working great. Awesome little mod!
  18. Smoothie
    1,431
    Nice one mate, so part number above correct? And price £26 for two or each?
  19. Staz
    6,206
    67
    I bought mine from another ASN member so I can't confirm the price or part number, sorry.
  20. NHN
    29,650
    1,799
    £35 now for a pair according to my latest update & superseded to a C on end, remove the 9B9 colour code as such, parts department will find these easily, I could get these for you, would cost little more for postage, would take few days to arrive at yours but your choice mate.
  21. Smoothie
    1,431
    Are they an easy fit mate? Would certainly get them off you if i went ahead with them, to the door saves me a lot of hassle
  22. NHN
    29,650
    1,799
    Piece of cake mate, others havnt had to extend any wiring at all so reckon you'll be ok, just put bonnet up & check the passenger one if it has some slack in the loom under the plenum chamber cover otherwise I can ask them to also include a repair wire to extend it minimally or you can just cut, join in 2 places with solder & tape up, your choice.
  23. Smoothie
    1,431
    ok mate il check that out
  24. JS3
    JS3 Member VCDS Map User
    227
    Hi Guys - sorry to bring this up from the past - have read a few posts stating the part numbers have changed.
    Is there a set of non-heated fan jets?
    What is the updated part number?
    Is this a VW or Audi part?
    Anybody know updated costs?
    Apologies for all the questions, but thanks!
  25. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,080
    I ordered a pair of 5MO 955 986 9B9 from Stoke Audi last year. Those are heated washer jets, VW parts and it was circa £35.
  26. N8
    17,160
    718
    They are a lovely lovely touch :wub:
  27. JS3
    227
    Guys - the S3 8P washer jets are located in the windscreen cowel, not the underside of the bonnet as per the A4 thread. Do they still fit this and are the same size?
  28. shady-ninja
    shady-ninja Active Member
    999
    53
    Can anyone post a video of how they wrk if its no too much to ask.
  29. SAiLO
    1,080
    There's quite a few videos on youtube, maybe not exactly showing a3 8p fan washer jets but should give you the idea.
    Here's my photo:
  30. MTRL
    MTRL Split Grill!
    459
    52
    Does anyone have a current link to where I can buy a set of these? Dont want to get the wrong type...
    Thanks,
  31. grr666
    grr666 Member
    171
    19
    +1. I'd be interested in a set for my 09 S3.
    My 54 skoda Fabia had (non heated) fan jets on it and they were better than the triple jets on my
    S3. Also, am I to believe my washers are heated? I've read through the thread twice and can't work out
    if they are meant to be or not? Or is it an optional thing?
  32. JS3
    227
  33. J.R.
    J.R. "Started From The Bottom" VCDS Map User
    1,404
    66
  34. Cruiser89
    Cruiser89 Advanced In Car Tech
    1,481
    220
    I don't think the actual fluid itself is heated. I believe it's just the nozzle itself to help if it freezes over.
    There is a product on the market called Heat Shot - Heat Shot
    Heated water on demand for your windscreen using your current jets.
  35. J.R.
    1,404
    66
    That Heat Shot is a great Idea ...but £180 ..is way overpriced.
  36. Cruiser89
    1,481
    220
    Yep I agree, plus you can then add on installation charge.
  37. southylad
    southylad Active Member
    544
    hi mate can you sort me out with a pair of these for my s line I had them on my passat sport tdi and they were great, ps builds received and fitted and look great thanks again for your help and advice , I am still thinking about the cruise and also the newer led back lights for my sportback I here you are the man for them also as soon as funds alloy I will give you a shout
  38. mike foster
    3,967
    Did you notice the date of NHN's post mate ? Knocking on 2 years now so as all prices have increased considerably I doubt it could be done at that price !!!
    I'm in Leeds should you need any help - but you know that anyway !
  39. southylad
    544
    Ha ha never even noticed date mate I do miss the fan jets from my passat tho so will have to way up the cost then cheers for that I wish there was a few more retro fitters and vcd guys round here! Mind you I would never have no cash but you can't take it with you eh
  40. mike foster
    3,967
    Anything VCDS I can do for you should you need it !
