Fan-tastic timing
Oranoco Oct 29, 2008
  1. Oranoco
    Oranoco Well-Known Member
    3,998
    408
    My heater fan has been a bit iffy for a while making a clicking sound when going. This morning with an iced up car it decided to pack up. When it did decide to blow it sounded sick and had no power to the blow.
    How much and where to get a new one? Car is a 96 with climate if it makes any difference.
  2. aragorn
    18,606
    871
    iirc they're on ebay for reasonable money
  3. Oranoco
    3,998
    408
    Will have a butchers. Cheers
  4. auroan
    auroan Active Member
    1,669
    You can have my heater fan from a 96 with climate cheap if you want.
  5. Oranoco
    3,998
    408
    New ones been ordered and paid for now :(
  6. jcb
    jcb Active Member
    4,132
    13
    I would be interested to see how much ball ache this is to fit. mine sounds a bit funky
  7. aragorn
    18,606
    871
    supposedly its quite simple. Glove box out, a few nuts and swap it over.
  8. Oranoco
    3,998
    408
    I'll let you all know Saturday/Sunday. Would pics be of any interest to people?
  9. jcb
    jcb Active Member
    4,132
    13
    yep
  10. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    It's the easiest job in the world (on an Audi), takes 10 minutes. The blower is right in front of you with the glovebox out, but there is a bracket above you need to remove in order to give you enough space to wiggle it out. Very obvious once you're in front of it.
  11. Oranoco
    3,998
    408
    Would say I would go outside now but unfortunately 2 things mean I won't.
    1. It's cold
    2. I'm going to the pub
  12. Oranoco
    3,998
    408
    Sorted.
    Really no need for any pictures as it took longer to make my coffee than it did to change the motor.
    Undo 5 8mm bolts that secure the glovebox 2 either side and one in the centre to by the locking tab.
    Drop the glovebox down (minding the 2 wires for the glovebox light)
    Ease off the 2 wires from the motor at the back left of the glovebox cavity.
    Undo the 5 retaining screws and ease the motor out.
    As Mr Haynes would say refitting is the revers of removal.
    My blowers now work, don't smell and actuall blow air when turned up.
  13. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    Great Stuff!
