Fan style windscreen washers
AR-CoolC Feb 15, 2010
  1. AR-CoolC
    AR-CoolC New Member
    24
    Hi All, I'm sure this will have been covered before, but the search function wasn't showing anything.
    I have a MY2010 A3 which has "normal" stream type washer jets. On my previous Octavia (and previous to that Leon) I had the fan spray type washer, which I personally think are much better.
    For all you part number guru's out there. Is there a fan washer for the 8P A3? and if so what are the part numbers, and is it a straight sawp?
    TIA
  2. beanoir
    beanoir Large Member
    2,171
    31
    HAve you done a search, I'm sure I've read threads about this before, IIRC Passat ones fit, maybe...
  3. Mick a3
    Mick a3 Mellow Yellow
    266
    Im sure they took the washer's from a passat if i remember correctly, and yes its a straight swap IIRC.
  4. AuldReekie
    AuldReekie Member
    770
  5. AR-CoolC
    AR-CoolC New Member
    24
    Thanks Chaps, now I know what to search for I found a few threads.
    For anyone else interested the part number for the Passat washers appears to be 5MO 955 986 9B9 at around £14 each.
    I'll do a bit more digging to ensure they are a direct replacement (there are a few mentions of the replacements being loose) and get back to this thread.
  6. mike foster
    3,967
    Hi - I agree the fan type are much better and am interested in doing the same swap. However the washers on my 2005 2.0tdi sportback are heated ( at least they have two wires connected to them ) and I wonder if the Passatt ones are as well. Thanks for the part number - pity my Etka only has Audi. Look forward to your follow-up
  7. Lee_R
    Lee_R Active Member
    2,499
    12
    Standard on my lupo too, weird that bottom of the range 10 year old vw's get them but new A3's don't!
  8. Pii
    Pii Member
    748
    PJMspeedy can supply the Passat ones for thoses that are too lazy to try a dealership. He had them sent to me within a few days but I have yet to fit them on.
    Speaking with some other guru's here the Passat ones are supposed to be a direct replacement even for the S3.
    Will update this thread when I get around to this.
    Pii
  9. JohnS3
    JohnS3 Active Member
    3,032
    Ask Staz, he fitted some last yeaar.
  10. PH1L
    PH1L Gievf Buckets
    3,851
    40
    yep thats right as the bonnets are the same id consider it, though tbh im too lazy to adjust my washer jets so i dont know about fitting a new set :p
  11. I'mRonBurgundy?
    I'mRonBurgundy? Lets make that kitten purr...
    554
    Excuse my ignorance but what's the difference?
  12. PH1L
    PH1L Gievf Buckets
    3,851
    40
    as opposed to a single line squirt in 4 places you get 4 fan shaped sprays
  13. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    4?? You get a fan spray on each side of the windscreen. Check out the FAQs thread to see what it looks like.
    They're a direct swap though yes :icon_thumright:
  14. LWNY
    LWNY Member
    161
    And does the swap allow me to keep the heated windshield nozzles that's std on the cold weather package?
  15. JohnS3
    3,032
    Yes, they are heated too.
  16. Pii
    Pii Member
    748
    Side track question but what is the cold weather package?
  17. PH1L
    PH1L Gievf Buckets
    3,851
    40
    yeah i recall someone fitting ones and getting more jets, mind you could just be my memory
  18. LWNY
    LWNY Member
    161
    Here in the colonies, cold weather package includes heated seats, nozzles and mirrors. Plus it comes with a ski sack.
    Does that mean non-heated nozzles suddenly becomes heated?
  19. mike foster
    3,967
    Mine hasn't got heated seats or ski bag or , in fact, a slot for the skis but it does have heated mirrors and washer jets ! :icon_thumright:
  20. Pii
    Pii Member
    748
    Right... finally got round to this which is techincally my first ever mod.
    It was a pretty straight forward job as most people explained on previous threads, even for someone like me who is incapable of mechnical work :sadlike:
    Anyway so the process is pretty much
    - unclip the old washer jets with a flathead screwdriver
    - remove two wires connected - 1 being the water pump and the other being the heated wires (both pretty straight forward)
    - connect the wires to the new fan washer
    - clip the washer jet back in place (the clips are not quite the same as the old ones but overall it fits). Be careful not to be over forceful as you could break the clip as I did. Thankfully the broken side clip didnt affect the over fitting of the washer.
    - the end product is maybe a 1mm gap at the front of the washer jets - has anyone else experienced this problem?
    Fan shape washers are pretty good and appear to reach the whole screen in one shot. Only thing is i finished testing and my car appears to have been sprayed on the roof and on the sides of the car. :think:
    Wil147 likes this.
  21. Staz
    6,206
    67
    The funny thing about the fan jets is if you adjust them so that they don't spray the roof when stationary you'll find the spray is too low when you're driving. You're better of testing them when driving and adjust as necessary. It took me a few stop starts down the road but it was done once and they've been perfect ever since.
  22. Pii
    Pii Member
    748
    Hey Staz
    It didn't occur to me this was possible. How do you adjust them?
    Both washers side by side - the clips are different but overall fan washers will fit it.
  23. Staz
    6,206
    67
    There's a tiny grub screw on the side or front or somewhere mate, I can't remember off hand.
  24. Staz
    6,206
    67
  25. Pii
    Pii Member
    748
    Thanks again Staz
    I'll take a look at it tommorrow to see if I can tweak the washer so that they do not spray innocent pederstrians nearby my car, despite how much fun this would seem :)
  26. 4NT
    4NT Terminal Douche Bag!
    368
    This just made my car feel even older! Having owned a few VW's before going into Audi it is weird that the lesser brand has slicker washer jets, aw jeeeeez :confused:
  27. martinivw
    martinivw :)
    455
    25
    Got my fan jets today(thanks Paul)
    I installed them ,tried them and reinstalled my old ones,
    They are not for me,
    Any one want cheap heated fan jets????????????????????????????????????????????????????????????
    Martin
  28. I'mRonBurgundy?
    554
    What didn't you like about them Martin?
  29. martinivw
    martinivw :)
    455
    25
    Not a good enough fit, ,
    if they fitted correctly they would be gr8,as the fan spray is spot on,
    I just dont think filling the (small) gap with silicone or RTV looks good,
    Just not how i roll
  30. I'mRonBurgundy?
    554
    Been looking at the pic in the earlier post of each unit side by side. Could the two be combined so the 'workings' of the Passat could be incorparted into the body of the Audi one?
  31. h5djr
    9,452
    1,765
    The size of the aperture for the washer jet unit must have changed. On my 2009 Sportback they fit just the same as the original washer jet unit. I tried a set of the fan-type and they fitted perfectly but I personally preferred the original 3-jet unit so I swopped them back.
  32. I'mRonBurgundy?
    554
    I'm interested in these but only if the fit is good. Has anyone fitted these to a 2008 model car?
  33. Staz
    6,206
    67
    Yes...
  34. h5djr
    9,452
    1,765
    But were they a direct fit in the same way as the original washers jet units or did you need to use any packing, silicon etc.
  35. Staz
    6,206
    67
    As I said in post 13 up there /\ they're a straight swap yes.
  36. h5djr
    9,452
    1,765
    Only trying to help the poster who asked if anyone had fitted them to a 2008 model to whom you gave the sortest possible answer. There is no need to be sarky!
  37. robby
    robby Active Member
    579
    69
    I'll take them off your hands - pm me with a price :)
  38. LWNY
    LWNY Member
    161
    Can't I just put a mesh screen in front of my current jet so that the streams scatter?
  39. robby
    robby Active Member
    579
    69
    Just fitted mine tonight but have a problem (apart from the gap) - the passenger side wires wont reach the plug connection on the jet? the connectors on the fan jets are facing the other way to the origionals and i can't stretch the wire enough to plug it in - anyone else had this problem?
  40. Pii
    Pii Member
    748
    Mine was a little tight initially but I was able to tug the wires out a little so they stretched far enough although this was no real challenge.
    When was your car registered as someone else on the forum might be able to provide some insight but may need some more details.
