Fan Style Washer Jet Upgrade / Aero Wiper Blades
g60leigh Feb 22, 2010
  1. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    TT washer jets update.
    the jets are the same plug fitting and fit the pipework. need trimming to fit into the scuttle and bonding in place.
    I have trimmed mine and trial installed them. all looks good but think I may need to extend the wiring to the N/S one.
    need time to bond them into the scuttle next as they want to spring back out, any suggestions for an instant grab strong adhesive so bond it straight down?
  2. Imteyaz
    Imteyaz 6th Gear
    535
    Any pics dude? It would help with giving you ideas on how to keep them in place.
    I normally use windscreen black sealant as it has good 'grab' but it still takes a few hours to cure, maybe something like that would help?
  3. Y83OLK
    Y83OLK Hulk Smash!
    841
  4. g60leigh
    1,674
    207
  5. g60leigh
    1,674
    207
    Ok just finished and WOW, well impressed with the improvement the fan jets provide.
    I used q-bond to get them set
    How it was done:
    Removed the old spray jets and used one of the wiring looms to extend one of the TT ones
    Trimmed the base of the TT jets to fit into the scuttle opening on the S3
    Fed wiring through connected and connected hose
    Lined up and bonded the TT jets to the Scuttle (had to raise the edge closest to the windscreen to get it to spray where I wanted it)
    added some of the q-bond filler powder and glued it up the fill the gaps and add strength
    just need to tidy up some of the over glue and filler but need my dremmel back first to do a good job of it.
    :rockwoot:
  6. Y83OLK
    Y83OLK Hulk Smash!
    841
    That Q-bonds good stuff eh'.
    Try and get some pics/ a video up of them.
  7. g60leigh
    1,674
    207
    Pre clean up pictures
    Pic's:
  8. A3Tomlin
    A3Tomlin Drive it like you stole it
    66
    Show us the fans!
  9. Imteyaz
    Imteyaz 6th Gear
    535
    Quick question: I thought that the jets could be adjusted by using a flat headed screwdriver on the barrell shaped part where there is a slot, thereby not needing it to be raised? Or did it run out of adjustment and require raising?
  10. g60leigh
    1,674
    207
    lost a lot of the adjustment when trimming (with hacksaw) did not want to get spray where I wanted it
    Not able to get a decent photo of the spray pattern - sorry
  11. whothafunk
    whothafunk New Member
    17
    *cough* *cough* bump *cough*
    pictures or videos of the installed TT jet spray would be awesome ;)
  12. <tuffty/>
    21,800
    4,171
    Pictures have gone :(
  13. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,130
    356
    What an anti climax! where are the pics!?
  14. dirtychinchilla
    dirtychinchilla Member
    184
    10
    BUMP! The washer jets used in this mod, what was the part number? I've found 8J0955987G, but I think that's for the 2009 TT, so I don't know if they're applicable.
  15. dirtychinchilla
    184
    10
  16. <tuffty/>
    21,800
    4,171
  17. dirtychinchilla
    184
    10
    As always, tuffty, you're the boss. Thanks a lot! :rock:
  18. dirtychinchilla
    184
    10
    tuffty, when you say you extended the wiring, is that a simple job? Noob here, as you may have realised. And with the different angle of hose fitting, what did you actually have to do to get it working?
  19. <tuffty/>
    21,800
    4,171
    I cut the longer wiring loom off the original washer and soldered it to one of the TT jets... the solution for altering the angle is in the post mate... out the box they are too close to the scuttle panel to get the hose on so I used a heat gun to soften the end of the jet using a 3mm drill to prevent it collapsing as I carefully bent it back... this gave enough clearance to get the washer hose on
  20. dirtychinchilla
    184
    10
    Thanks a lot. Pretty obvious solution to the loom problem! Not that I thought of it at all.
    I did see the modification to the angle in the post, but needed a full description because I'm not 100% sure what I'm doing. Again, thank you very much.
