Fan still running after car switched off
~RS~ Dec 21, 2013
  1. ~RS~
    ~RS~ Active Member
    1,466
    22
    Ok I know this is a common problem with the earlier 8P's and I've read the threads on it being the temperature sender on the block, but my cars issue has a twist to it......
    So the cooling fan on the radiator is spinning when the car is off (no key in ignition). It sounds like a jet plane and has drained the battery on my car. Basically the battery was dead yesterday morning I asked a mate to give me a jump start, it wouldn't start as the battery was completely drained. However we noticed that the fan was coming on at full pelt, and there was a clicking sound coming from the fuse box (under bonnet). Upon inspection- the relay (which I have since discovered is the fuel pump relay) was clicking away like one of the San Bushmen from South Africa lol :D I took this relay out as I didn't like the constant clicking and the fan stopped spinning, result! Yeah right... Now car won't start, I now figure the relay does more than stop the fan spinning so out comes the battery to be charged as I didn't realize it was the fuel pump relay I'd pulled out just yet
    4 hours later the battery has enough juice to start car up, but it won't start, light bulb goes off in my head and fuel pump relay gets fitted back into place, but car still doesn't start. Few mins and a fuel pressure warning sign later it turns over and starts up. I drive it for about 7 mins and the car conks out, on a roundabout (its a dsg may I add :p) so I embarrassingly push it off the roundabout and proceed to try and get the bloody thing started. Roughly another 7 mins goes past - by this point the fuel pump relay has been in and out loads of times, because although I know the car won't start without it in I still haven't figured out it's the fuel pump relay.... finally the car starts back up and I drive back home.
    I sit in the car outside my home with it in 'N' position on the gearstick for a few mins to see if it conks out again and it does. Then I try restart it and it takes an age to start up runs for a few mins and conks out again. So I dig out the dodgy vag com lead I have and run a couple of scans it's getting cold so I call it a day and pull out the fuel pump relay (part no:1K0 906 381) to stop the fan from spinning and killling the battery again. Get upstairs and run the relay part number discovering that it controls the fuel pump too.
    Any help here would be great, absolutely ****e timing considering I still have a few xmas pressie to buy lmao, and it's bloody freezing outside :( VCDS scan results are below, my lead isn't OG and didn't complete the first scan for some reason. 2nd one post clearing the fault codes ad restarting the car ran to the end though.
    In case your wondering which relay I pulled it's the one marked light grey one marked 458 in this pic:
    Edit: here are those vcds scans-
    Scan1:
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 77 7D
    01-Engine -- Status: Malfunction 1010
    02-Auto Trans -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: None
    Part No HW: 028 101 189 2
    Revision: 12345678 Serial number: AUX7Z0D9FNT0NO
    VCID: 55A58567BC1A496
    3 Faults Found
    16706 - Engine Speed Sensor (G28)
    P0322 - 000 - No Signal
    Freeze Frame:
    RPM: 0 /min
    Torque: 164.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 9.96 V
    Bin. Bits: 00000111
    Idle Stabilization: 0.0°KW
    RPM: 84 /min
    19781 - Power Supply Terminal 15
    P3325 - 000 - Implausible - Intermittent
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.86 V
    Bin. Bits: 00000111
    Bin. Bits: 0
    (no units): 1.0
    19463 - Camshaft Position Sensor (G40)
    P3007 - 000 - No Signal - Intermittent
    Freeze Frame:
    RPM: 84 /min
    Torque: 34.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.01 V
    Bin. Bits: 00000111
    (no units): 16.0
    Readiness: N/A
    Address 02: Auto Trans Labels: None
    Part No HW: 02E 927 770 AD
    Revision: 00004010 Serial number: 00000410180173
    1 Fault Found
    18258 - Powertrain Data Bus
    P1850 - 000 - Missing Message from ECU - Intermittent
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0104
    Coding: 0023174
    Shop #: WSC 06435 000 00000
    VCID: 3A7F36DB754486E
    2 Faults Found
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    004 - No Signal/Communication - Intermittent
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 E HW: 8P0 820 043 E
    Component: KlimavollautomatH13 0150
    Revision: 034069 Serial number: 8P0820043
    Shop #: WSC 06314 000 00000
    VCID: 2E570A8BB90C5AE
    2 Faults Found
    01274 - Air Flow Flap Positioning Motor (V71)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 212
    Mileage: 190026 km
    Time Indication: 0
    Freeze Frame:
    Raw, Form. N/A: 000 000 135
    Temperature: 14.0°C
    (no units): 165.0
    (no units): 37.0
    Temperature: 10.5°C
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 00:11:20
    Freeze Frame:
    Voltage: 7.80 V
    Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
    Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
    Component: Bordnetz-SG H54 2501
    Revision: 00H54000 Serial number: 00000007998692
    Coding: F3081E8290141C004F0000003000000000084E0364360802000000000000
    Shop #: WSC 12435 123 12345
    VCID: 458555270CBAF96
    Subsystem 1 - Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 12435
    Subsystem 2 - Part No: 4E0 910 557
    Component: REGENLICHTSENSORH10 0050
    Coding: 00150573
    Shop #: WSC 12435
    4 Faults Found
    00988 - Lamp for Brake Light; Right (M10)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 177
    Mileage: 189176 km
    Time Indication: 0
    Date: 2013.10.25
    Time: 20:48:00
    Freeze Frame:
    ON
    Voltage: 11.90 V
    ON
    ON
    OFF
    OFF
    ON
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 00:14:00
    Freeze Frame:
    OFF
    Voltage: 7.05 V
    OFF
    OFF
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 11:41:00
    Freeze Frame:
    ON
    Voltage: 9.10 V
    ON
    ON
    OFF
    OFF
    ON
    00318 - Supply Voltage for Rear Lid Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 4
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 11:41:00
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H10 2620
    Revision: 91H10262 Serial number: 00362000Z4FM
    Coding: 0034622
    VCID: 428F4E3B1D94CEE
    1 Fault Found
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 21
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 00:12:14
    Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
    Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
    Component: J0527 H36 0070
    Coding: 0014112
    VCID: 418D41371892D56
    Part No: XXXXXXXXXXX
    Component: E0221 H06 0030
    No fault code found.
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
    Component: KOMBIINSTR. VDO H73 0300
    Revision: D04 Serial number: 2249DD04002426
    Coding: 0000443
    Shop #: WSC 00022 210 98720
    VCID: 366722EB415C62E
    1 Fault Found
    00668 - Supply Voltage Terminal 30
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 0 km
    Time Indication: 0
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 2500104A06018A
    Coding: 3F3F0BCA072103
    Shop #: WSC 00000 000 00000
    VCID: 285BFC939BE804E
    1 Fault Found
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 9
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 11:41:15
    Address 25: Immobilizer Labels: Redir Fail!
    Revision: D04 Serial number: AUX7Z0D9FNT0NO
    Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
    Part No SW: 8P0 035 192 H HW: 8P0 035 192 H
    Component: RNS-E HIGH EU H72 0660
    Revision: 01S Serial number: AUZBZ7F0957072
    Coding: 0205755
    Shop #: WSC 06314 123 00000
    VCID: 346318E3572070E
    Part No: 8P0 035 192 H
    3 Faults Found
    00446 - Function Limitation due to Under-Voltage
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Address 42: Door Elect, Driver Labels: None
    Part No: 8P0
    Component: Tuersteuerger. H10 0030
    Coding: 0000048
    VCID: B87BACD3CB4814E
    2 Faults Found
    01811 - Supply Voltage for Door Controller; Drivers Side (J386)
    00913 - Window Regulator Switch; Front Right Driver (E81)
    008 - Implausible Signal - Intermittent
    Address 44: Steering Assist Labels: Redir Fail!
    Part No: 1K2 909 144 H
    Component: EPS_ZFLS Kl.8 1502
    VCID: 316D11F7A832456
    3 Faults Found
    Freeze Frame:
    Mileage: 280 km
    Temperature: 6.0°C
    Voltage: 7.20 V
    Voltage: 8.10 V
    Freeze Frame:
    Mileage: 280 km
    Temperature: 4.0°C
    Voltage: 8.60 V
    Voltage: 10.00 V
    Freeze Frame:
    Mileage: 280 km
    Temperature: 8.0°C
    Voltage: 6.10 V
    Voltage: 6.00 V
    Address 46: Central Conv.
    Cannot be reached
    Scan 2 (after clearing codes and restarting car)
    Chassis Type: 1K0
    Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72 77
    7D
    00-Steering Angle Sensor -- Status: OK 0000
    62-Door, Rear Left -- Status: Malfunction 0010
    72-Door, Rear Right -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 DT HW: 028 101 189 2
    Component: R4 2,0L EDC 0000AG 7000
    Coding: 0000078
    Shop #: WSC 66565 257 00032
    VCID: 78FBECD30BC854E
    3 Faults Found
    Freeze Frame:
    RPM: 0 /min
    Torque: 164.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 9.96 V
    Bin. Bits: 00000111
    RPM: 84 /min
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.86 V
    Bin. Bits: 00000111
    Bin. Bits: 0
    (no units): 1.0
    Freeze Frame:
    RPM: 84 /min
    Torque: 34.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 12.01 V
    Bin. Bits: 00000111
    (no units): 16.0
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans Labels: 02E-300-0xx.lbl
    Part No SW: 02E 300 041 A HW: 02E 927 770 AD
    Component: GSG DSG 041 0822
    Coding: 0000020
    VCID: 102BB47303786CE
    1 Fault Found
    Coding: 0023174
    2 Faults Found
    Revision: 034069 Serial number: 8P0820043E
    2 Faults Found
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 212
    Mileage: 190026 km
    Time Indication: 0
    Date: 2013.12.10
    Time: 18:47:19
    Freeze Frame:
    Voltage: 13.50 V
    Temperature: 14.0°C
    (no units): 165.0
    (no units): 37.0
    Temperature: 10.5°C
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 2
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 00:11:20
    Freeze Frame:
    Voltage: 7.80 V
    Coding: Long Coding
    Coding: 00062736
    Shop #: WSC 12435
    Coding: 00150573
    Shop #: WSC 12435
    Part No: 8P0 907 279 K
    No Faults Found
    or DTCs not supported by controller
    or a communication error occurred
    1 Fault Found
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 21
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 00:12:14
    Coding: 0014112
    Coding: 0000443
    Part No: 8P0 920 981 A
    No Faults Found
    Serial number: 1K
    Part No: 1K0 907 530 D
    No Faults Found
    Cannot be reached
    Coding: 0205755
    3 Faults Found
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 00:14:42
    Freeze Frame:
    Voltage: 8.80 V
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 00:14:42
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 00:14:42
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX1.lbl
    Part No: 8P0 959 801 F
    Coding: 0000048
    VCID: 3E773ACB696CAAE
    2 Faults Found
    3 Faults Found
    Freeze Frame:
    Mileage: 280 km
    Temperature: 6.0°C
    Voltage: 7.20 V
    Voltage: 8.10 V
    Freeze Frame:
    Mileage: 280 km
    Temperature: 4.0°C
    Voltage: 8.60 V
    Voltage: 10.00 V
    Freeze Frame:
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 C
    Component: KSG H04 0050
    VCID: 3C7330C37F70B8E
    No Faults Found
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH03 0180
    VCID: F1ED51F7E8B2856
    Part No: 8P4 035 382
    No Faults Found
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MAX1.lbl
    Part No: 8P0 959 802 F
    Coding: 0000048
    VCID: 3F8947CF6E66A36
    1 Fault Found
    01812 - Supply Voltage for Door Controller; Pass. Side (J387)
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Coding: 0205755
    3 Faults Found
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.20
    Time: 00:14:42
    Freeze Frame:
    Voltage: 8.80 V
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 3
    Reset counter: 217
    Mileage: 190311 km
    Time Indication: 0
    Date: 2013.12.19
    Time: 22:46:18
    Freeze Frame:
    Voltage: 10.50 V
    Mileage: 190310 km
    Count: 2012
    Clock: 02:07
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 14
    Reset counter: 64
    Mileage: 174187 km
    Time Indication: 0
    Date: 2012.06.29
    Time: 20:16:58
    Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 B
    Component: Tuer-SG H10 0010
    Coding: 0000144
    1 Fault Found
    01813 - Supply Voltage for Door Controller; Rear Left (J388)
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 B
    Coding: 0000144
    1 Fault Found
    01814 - Supply Voltage for Door Controller; Rear Right (J389)
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Part No SW: 8P0 862 335 N HW: 8P0 862 335 N
    Component: FSE_256x BT H34 0520
    Revision: 00000000 Serial number: 00000005023259
    Coding: 0011422
    Shop #: WSC 63140 123 00000
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element
    Revision: 00800000 Serial number:
    VCID: 2D550D87B40A216
    End ---------------------------------------------------------------------
  2. Boon
    Boon Active Member
    441
    59
    Don't think you'll get much help here by using a copy VCDS cable but the clues are in the scan!
  3. ~RS~
    ~RS~ Active Member
    1,466
    22
    Hi Boon,
    Fair point about the hex can cable... I haven't been about for a bit, Nigel was the only one selling them back then ad he knows I'm a good lad :)
    I think I can see what your alluding to in the scan, most of the faults seem to be because I've removed the battery or the fuel pump relay (I think anyway) but the one that points to the cause of the cutting out would be 16706 - Engine Speed Sensor (G28) and 19463 - Camshaft Position Sensor (G40) the ross wiki says symptoms are:
    Engine shuts off
    Engine doesn't start
    Speedometer inoperative
    Glow Plug Indicator Lamp (K29) flashes
    Which all occured.
    It also states that:
    The Engine Speed Sensor (G28) is also used as a reference sensor for the crankshaft position
    Does this mean that the Engine Speed Sensor is also the crankshaft position sensor?
    How come the intercooler fan is running after the car is off though? There are no codes relating to the temp sender being faulty...
    I should add in my infinite wisdom I tried to start the car without the fuel pump relay pulled out, I didn't realize at the time this was the fuel pump relay, would this have caused any issue with the engine speed sensor because I've not had cutting out issues before the fan drained the battery.
    Also, what would have been making the fuel pump relay click away like that when the car was off and the fan was spinning?
