fan not blowing hot air?
timontour Mar 17, 2013
  1. timontour
    timontour Member
    37
    hi all, my heater fan seems to have packed up, the bars go up and down on the climatronic but the fans not blowing any air
    any ideas anyone?
    thanks
  2. chris.vincent3
    chris.vincent3 Own a BMW now, HOWEVER I still own VCDS! VCDS Map User
    604
    34
    blocked pollen filter?
  3. timontour
    timontour Member
    37
    pollen filter was changed last service 3 months ago, just checked the fuse and thats ok
    anways happens when its cold
  4. shariain
    shariain Well-Known Member
    1,182
    190
    Have it scanned with VCDS.
    The fact that its not blowing any air when its cold could be a selector flap that is not moving when it should be.
  5. Ironborn
    Ironborn English...not so good
    1,179
    227
    Is the car overheating? Waterpump?
  6. dany2k
    dany2k Member
    318
    Similar problem in my old A3 8L turned out to be the thermostat... probably worth scanning first or if you don't have access to vagcom start small and go for the thermostat!
  7. Rom
    Rom Member VCDS Map User
    443
    As said, does the car temp show its warmed up properly ?
    Does it blow hot air if you rev it a lot, or on motoroway etc.
    Either hot coolant isnt getting to the matrix, or the control isnt allowing the hot air through.
  8. chris.vincent3
    604
    34
    Where you based Timontour, one of us kind people will scan your car with VCDS if you don't have it.
  9. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Tim, if the bars on the display are moving up and down, you should clearly hear the fan spinning. If there is no noise from the fan, then suggest that the fan motor has quit. If you can hear the fan, and there is no air coming out, then the flaps are suspect. A scan would help.
  10. indo247
    indo247 Member
    54
    heres the vag com scan, looks like the motor has gone?
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
    Component: KlimavollautomatH19 0360
    Revision: 130321 Serial number: 8P0820043AC
    Shop #: WSC 00000 000 00000
    VCID: 6DFF15C27444E870FAA
    1 Fault Found:
    01273 - Fresh Air Blower (V2)
    003 - Mechanical Failure
    Freeze Frame:
    Fault Status: 01100011
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 230
    Mileage: 140399 km
    Time Indication: 0
    Date: 2013.03.16
    Time: 08:59:30
    Freeze Frame:
    Temperature: -50.0°C
    Speed: 42.9 km/h
    (no units): 54.0
    (no units): 165.0
  11. NHN
    29,328
    1,708
    If you cant hear the fan motor in the passenger footwell then the fan unit has gone, hence why the bars up/down are not making difference & according to that log it is this, so its either got no power or its buggered & needs changing.
    Depends where you are, but I can source a new one & replace.
  12. indo247
    indo247 Member
    54
    thanks NHN, i cleared the fault on vcds and spoke to my local mechanic he suggested that it might just have a leaf or debris jammed in it and the bang on under the glove box so i cleared the fault ond gave it a thump vola its now working? nut it may be a sign of things to come? any idea on the cost of a new motor?
  13. dk1234
    dk1234 Member
    195
    I've got the same problem and I have the same fault code as I've just quoted. What is needed for this a new fan motor or blower motor? are they the same thing?
  14. NHN
    29,328
    1,708
    You need a new fan/blower motor.
    dk1234 likes this.
  15. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    You guys starting to suffer from the same issue as us B5 owners, where the brushes wear out and the copper end of the motor wears down?
  16. NHN
    29,328
    1,708
    Yeap its the same issue completely as I've stripped some down to research/investigate, not worth even trying to replace parts just the whole unit I found.
  17. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,751
    353
    That's a pretty sweet sig you've got there!
  18. indo247
    indo247 Member
    54
    mines been ok since, no faults
  19. ScottD3
    15,161
    1,121
    Depends on cost and how handy people are with the required tools.
    I've replaced mine cause it was cheaper and not a big job really, since you got to the unit out any way.
    Once the fan unit it self is warn away I will have to replace it all.
    How much is a new fun unit?
  20. dk1234
    dk1234 Member
    195
    I took out my blower motor today, should the "hamster cage" spin? mine doesn't move, any reason for this?
  21. NHN
    29,328
    1,708
    If it doesn't manually spin then its goosed more than likely, replace for new one.
    dk1234 likes this.
