FAILED MOT ON B/PADS+ AND GOT AN ADVISORY FOR AIRBAG LIGHT & NO EPC WORK THAT OUT
tommytonguedj Aug 30, 2012
  1. tommytonguedj
    tommytonguedj Member
    133
    Evening All,
    As some of you may know i've been doing a bit of stressing due to mot coming up and airbag light not going out and no epc on dash on startup. Just been for mot all as i failed on was front pads, Both headlight aim & no servo assistance in pedal. The advisories was a long list but Airbag light on was the main one i was concernd about, So now i'm praying my front discs & pads come in the morning so i can fit them then try and find a boost leak fo servo or place servo and take it straight back for a partial retest.
  2. olly quattro
    olly quattro Member
    78
    Airbag light is often just a loose connection under the drivers or passenger seat on the airbag connector
  3. MarKC7899
    MarKC7899 New Member
    Also worth checking the connections to the 2 crash sensors by each headlight
  4. Ste_Nova
    Ste_Nova Active Member
    1,223
    47
    so a big fuss over airbag light...... but you had no brakes?????!!!!!
  5. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    If the EPC light doesn't come on when you turn the ignition then the MOT now assumes that you've removed to bulb to disguise a problem that causes increased emissions, that's why you got an advisory for no EPC light.
  6. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,250
    192
    What engine you got?
  7. tommytonguedj
    133
    It's 1.9 tdi engine, I was stressing due to the vosa website stating if no enigine management lights come on at start or if the airbag light stays lit it's a fail that's why i ordered new headlight/crash sensor wiring looms as my front crash sensors had been cut.
    My brakes which i knew was shot was in the post lol but ironically they turned up the morning after the mot they are now fitted i have also flushed the fluid and the pedal creeping down has gone. So all as i need now is the headlight alignment and all is good
  8. tommytonguedj
    133
  9. PetrolDave
    1,559
    85
    They're not suspended it's just that the implementation has been delayed, so at the moment they won't be a fail (as was planned) but you will get an advisory for them.
  10. AudiLeon
    2,250
    192
    Spongey brakes on the 1.9tdi can be connection on the vacuum pump.
    It's got a really bad connection into the pump it's self I took mine off, sealed it up and closed over the edges. Spongey brakes gone.
