Failed MOT on an AMD remaped S3 due to emissions
S3_Shaun_84 May 12, 2006
  1. S3_Shaun_84
    S3_Shaun_84 New Member
    Just taken my car for an MOT and it failed on the emissions, the MOT person said it appears to him the car has been tuned which seems to be causing the problem. I hadnt said anything to him about the map that AMD did. So i rang AMD to ask if it was true there maps could cause the car to over fuel and they said it was a load of **** which i do believe, and said it would be one of my sensors that has gone down.
    Readings are as follows:-
    FAST IDLE TEST:
    CO - <0.30 - ACTUAL READING 1.11%
    HC - <200PPM - ACTUAL READING 36PPM
    LAMBDA - 0.970-1.030 - ACTUAL 0.969
    SECOND FAST IDLE:
    CO - <0.30 - ACTUAL READING 1.20%
    HC - <200PPM - ACTUAL READING 51PPM
    LAMBDA - 0.970-1.030 - ACTUAL 0.964
    NATURAL IDLE:
    CO: - <0.50 - ACTUAL 0.48
    Just wondered if any one else had come across this problem?
    Im having some one do the fault code reading to see if a sensor has failed.
    Shaun
  2. S3_Shaun_84
  3. Ess_Three
    Ess_Three Active Member
    5,383
    14
    My APR mapped S3 did the same.
    Wouldn't pass with a 100 cell cat on regardless of the map in use.
    With the 200 cell it was touchy...unless the cat was red hot...
    Basically...I had to put the car into the standard map to get it through the MOT with ease...
    It was a pain in the butt.
    Mine had no sensors faulty...
  4. S3_Shaun_84
    Thanks for your reply mines fully standard apart from the map, ive spoke to AMD they say i need to get a fault reading done as they think a sensor is down i wont be pleased if i need to put it in standard mode cos mines a fixed map, surley these companies shouldnt be alloud to sell this product if its goin to fail emmisions without telling you?
  5. djmotorsport
    djmotorsport Member VCDS Map User
    78
    [ QUOTE ]
    [/ QUOTE ]
    Thanks for the info - It's going in for it's MOT on May 25th.
    DJ
  6. imported_bubstar
    imported_bubstar Guest
    Shaun, your figures are WAY out!! /ubbthreads/images/graemlins/blush.gif
    There must be a fault with a lambda sensor I would think. Worst case the Cat' could be knackered.........................
    I'm with AMD on this one a re-map using standard injectors will be fine - the test is carried out at idle and fast idle under NO load - why would a re-map affect these settings?
    Take a look HERE .
    BUB /ubbthreads/images/graemlins/beerchug.gif
  7. Ess_Three
    5,383
    14
    [ QUOTE ]
    DJ
    [/ QUOTE ]
    David, I thought the other David may have mantioned...
    Make sure they get the cat nice and hot...and with it in the standard map, it'll pass.
    It never passed in either chipped map with my 100 cell cats...but David R had the 200 cell cats fitted...so it may be better.
    But hot cat and standard map = /ubbthreads/images/graemlins/ok.gif
  8. Ess_Three
    5,383
    14
    DJ,
    I take it you have the pin code for swapping maps?
    If not, let me know...and I'll PM it to you.
  9. djmotorsport
    78
    Can you PM it to me please? - Dr R gave it to me but I can't remember it :-(
    TIA
    DJ
  10. Ryanc
    Ryanc Active Member
    1,321
    Mine passed with flying colours with 100 cell cat. You can have it tuned at idle to pass if it's a custom map.
  11. Broken Byzan
    13,237
    465
    Those readings are mile out, i agree with AMD on this, get the car VAG'd
