Failed MOT, due to 2009 rear lights??
gazzaw888 Jul 2, 2010
  1. gazzaw888
    gazzaw888 Member
    30
    Hi guys
    recently fitted 2009 rear lights the part no's i bought from audi dealer were
    A8P3 945 096
    A8P3 945 095
    "incorrect rear light clusters fitted to vechile has failed mot o/s/r fg lamp emits light other than red"
    this is what i failed my mot on, did i buy the wrong parts? have to now fit my old iights on and get the car down the garage tomorrow morning early doors, pain in he bum
    any help would be much appreciated
    cheers
    gary
  2. HIGGINS
    HIGGINS Member
    528
    15
    not a clue but just fit your old lights, get it mot'd and than fit your 09 lights as it takes 5 mins
  3. paddy
    paddy Audi=No fault code, no idea
    5,184
    137
    And what then is the point of an MOT ?
  4. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    can you ask the garage for a bit more info on it?
    Is it when the rears are lit, other bulbs light up too???
    Must admit, when we fitted mine for Inters, the passenger side one was a bit odd. When the bulb holder was snapped on the brake light didnt work, pull it away a bit and it works. There are no problems with contacts, seal etc and all the connections looked good. All bulbs seemed ok too. Odd.
  5. VWAddict
    VWAddict Member VCDS Map User
    656
    9
    "Emits light other than red" suggests that either another light bulb (reversing or turn signal for example) is coming on with the fog, as Sarah suggests, -or that you have a wrong colored bulb in there, like an Amber bulb.
    Did you have the rear clusters re-coded in VAG-COM when you did it? -If so (or if not) are they CORRECT?
    Also, you've told us what it failed for and what the wording is, but you haven't told us what's actually HAPPENING from your own observation. -Have you actually stood behind the car and made a note of what's actually happening when you engage the rear fog lights? -This is important information to all of us.
    -Incidentally, IF their report is actually wrong, you can challenge the failure at another MOT test station, and have the cost of the original test refunded. -In such a case the MOT station which wrongly failed the vehicle initially gets a note. -Too many notes and they get a visit.
    So I'm wondering if there really IS a problem. -Certainly, if the rear fog switch lights up either the reversing bulb or the turn signal bulb, then they are quite correct to fail the vehicle.
    Also, the SPORTBACK 09 rear light clusters are not plug-and-play; since they have a completely different connector to the 08-and-earlier rear clusters, so you must have an adaptor harness in there somewhere.
    Either a wrongly-wired adaptor harness OR an incorrectly-coded vehicle will cause the wrong bulbs to light up (since the tail lights of the A3 are definable in software).
    Not sure if you have a sportback or a 3-door...?
    So first we need to know what actually happens when you switch on the fog lights (I don't think you've told us that bit yet). -Then we mighe be better able to help you.
    But there's no way a car can be failed "due to 2009 rear lights" unless they're wrongly wired or incorrectly coded, without the test station risking an appeal.
    Keith
  6. philipjmarshall
    philipjmarshall Member
    91
    Gary,
    have you seen visible white light emitted from osr fog light for yourself??.
    is the car a 3 door, i think 3 door lamps have nsr white lens for reversing light and osr for mandatory fog light.
    has left hand drive lenses been supplied in error??
    just a thought.
    my five door lamps have fog lights in both.
    Philip
  7. paddy
    5,184
    137
    As Sarah says....more info needed...o/s/r fg lamp emits light other than red"...so what colour is it ??
  8. Sarah's A3
    5,920
    30
    Just out of interest, they arnt US spec ones are they??? Dont they have different coloured bulbs??? (not too sure but my A6 ones were different lol)
  9. gazzaw888
    gazzaw888 Member
    30
    sorry was out changing them over to the old style lights as i im going out in a bit, i have a 3 door a3 sline 170, i was told these lights are plug and play? do yous guys have the correct part no's as i remember when i was looking into these lights that the eu (non uk) lights would fail an mot due to a bulb being in the wrong place? thinking this is what audi have ordered me in
  10. Sarah's A3
    5,920
    30
    Were they brand new from Audi?? if so, take them back and ask them to check they are the correct ones.
  11. Lee_R
    Lee_R Active Member
    2,499
    12
    If its a 3 door then it sounds like you have a LHD drive cluster. No need to swap the pair over for your MOT tomorrow, just switch the drivers side one over to your old spec. Sportbacks have a fog in both sides so i'm guessing yours is a 3dr
    and Paddy, the MOT can be quite pointless. I used some double sided tape to put legal plates over the top of the illegally spaced ones. I put them on before putting the car on the ramp and took them off whilst still in the garage after it had passed! I've also borrowed 2 steels off my moms Polo to put on my Lupo because the tyres were knackered due to running crazy camber It looked stupid with different sized tyres and 2 steels/2 alloys but it passed no problem. The MOT proves that the car passed at that point, that is all!
  12. gazzaw888
    gazzaw888 Member
    30
    so if i swap the cluster over on the driver side mot pass? abracadabra, sorry started drinking cider to get over andy murray going out to the machine Nadal :(
  13. robby
    robby Active Member
    579
    69
    my part numbers have the letter A after the number, maybe yours aren't UK spec lights?
  14. HIGGINS
    HIGGINS Member
    528
    15
  15. gazzaw888
    gazzaw888 Member
    30
    did yours pass MOT ok Robby? think thats the problem gonna try swaping them with audi tomorrow cheers for all your help with this guys plus sarah lol
  16. paddy
    5,184
    137
  17. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    I got an MOT for a 1981 Mk3 Escort with no passenger side floor.
    cost me £40 though, and that was when £40 was a lot of money!
    Paddy will remember that.:yes:
  18. paddy
    5,184
    137
    Sorry mate...when you reach my great age your memory goes :bye:.... I did get £70 worth in the old A3 today for the first time......Now back in 1976 i remember getting a pounds worth in the Suzuki 250 and that was about 1.5 gallons....so that was about 18p/ltr.....:faint:
  19. paddy
    5,184
    137
    In those days i supported Newcastle......they made the final in 76 with Malcolm Macdonald and Mickey Burns...It wasnt really anything to do with the Football, more the Newcastle Brown that we all loved :lmfao:
  20. Sarah's A3
    5,920
    30
    ???? Newcastle! How come if you're a southerner!!!
  21. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Reckon my old MOT guy had a `Broon` lunch before hand too.
    Kept a few of my old sheds on the roads for bit if nowt else.:)
    Who would have thought, Pad the closet Geordie.
    Salute bonny lad:icon_thumright:
    Paul
  22. paddy
    5,184
    137
    Dear oh dear...women !!!! Read the post... Newcastle Brown was a very nice ale :))
  23. Sarah's A3
    5,920
    30
    Hate the stuff lol, prefer guinness!
    I read it! But read it as both bit part supporter and drinker!!!
    be nice or you can cook your own burger haa haaa
    Edit... no you can cook your own as you like it so much.
  24. HIGGINS
    HIGGINS Member
    528
    15
    Sorry was in a fowl mood :p
  25. robby
    robby Active Member
    579
    69
    Haven't had MOT with them fitted - yet
  26. smudge_don
    smudge_don Active Member
    2,944
    Sounds like you got a LHD set of rear lights, so the rear fog light would look like a reverse light
  27. gazzaw888
    gazzaw888 Member
    30
    took a while for the parts to arive but Audi swapped them for RHD pair :) mix up with my original order
  28. smudge_don
    2,944
    Told ya ;)
