failed MOT as rear levelling sensor missing
Mr R Mar 24, 2013
  1. Mr R
    Mr R New Member
    Hi all, S3 8L just failed MOT as rear levelling sensor missing!! But as car lowered before I bought it, assumed it has been removed as rear axle at different angle now! How have you others coped with this problem and am I just being daft and a new one will fit back on easily no probs?! HELP
  2. Shane-Ireland
    Shane-Ireland Member Team Ibis Team V6 Audi S3 quattro Audi A4 Audi Avant Owner Group TDi
    270
    22
    If the car is lowered Mr R then the leveling sensor won't work as it will be out of range. Presumably you can just fit one,get headlights adjusted manually and leave the self leveling disconneted. I did this on my old Bora and it passed the Irish NCT (our MOT)
  3. s33nyboy12
    s33nyboy12 Well-Known Member
    1,484
    196
    Oh my mate s3 light leveller is broke and what a ****ter to see at night! The lights literally light up 20 cm in front of the car... Without full beam it was very hard to see.
    sean
  4. superkarl
    superkarl MAN OF STEEL
    9,423
    2,382
    Adjust them manually. I snapped the arm on my sensor, so fixed the light at MOT pass level.
  5. <tuffty/>
    20,992
    3,760
  6. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Mine is fixed with cable ties passed the MOT 2 weeks ago no probs :)
  7. Mr R
    Mr R New Member
    Exactly! Since this week all systems for levelling and washers should work from factory as intended. So gonna buy another sensor, fit it so I can re-align lights and fingers crossed. Not sure how as its lowered though........
  8. Mr R
    Mr R New Member
    Two weeks ago was before new BS rules.....
  9. superkarl
    9,423
    2,382
    Be very rare that you get a jobsworth mot tester that will pull anyone up on washers and level sensors.
    I watched everything my tester did last week for the ST (main dealer too), headlight level checked, it was right, so he moved on to the brakes.
    Obv everyone wants a thorough inspection, but no one will be that thorough
  10. Mr R
    Mr R New Member
    Well I must be unlucky coz he did go over everything but I think it might be just because the level sensor isn't there at all!!
  11. Lewis583
    956
    91
    You say "jobsworth" but if it got let through when it should have failed the Tester risks his license and possibly his livelihood.
    Also for the record, the changes only got implemented on the 20th. So prior to that, leveling etc wasn't a RfR (Reason for rejection).
  12. Mr R
    Mr R New Member
    Has anybody else had a similar issue with lowering their car and having to disconnect this levelling sensor?
  13. Tooks
    Tooks Active Member
    753
    29
    You need to refit a rear sensor, and then adjust using VCDS.
    You can set them up on a lowered car, you just need to put the headlights into the adjustment position, adjust the lights manually, then finish the VCDS process so that the car learns the new level.
    My car is lowered, and the lights work fine.
  14. jojo
    28,856
    3,516
    This sensor does not need to be disconnected/removed for lowered cars. A lot of fitters forget to disconnect it from the track arm during a suspension change, and damages it as a result.
