Facts and Figures But Whats The Cause
basscrazy Oct 24, 2008
  1. basscrazy
    basscrazy Member
    60
    Ok ive failed mot originally them saying the wiring for lambdas was wrong
    Ive learnt in the past to get all my facts and figures in before going into things and i have done so
    Its been looked at by a sparky and hes said the wiring is not the cause and the garages who diagnosed it were wrong
    My cats have been tested and are working fine (they had only done 6k anyhow)
    Ecu is Fine
    But These are the proper stats (will help Ard as well buddy)
    Co = 5.00
    Hc or Mc (i cant read his dam writing)
    203
    co2 = 11.71
    02 = 0.40
    Lamda = 0.874
    Also the wiring chap when scanned my car etc said it was showing the error
    Exhaust supercharger recirculatnig valve
    They have said since this is not supercharged it could relate to a part labeled as this
    So theres my facts and figures
    New maf fitted new lambdas cats good etc
    Cheers Guys
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
    natural idle? fast idle? can't you just scan the print-out and post it here?
  3. basscrazy
    basscrazy Member
    60
    natural idle 0.02 co and 5.00 fast i updated first post with all he wrote down
  4. basscrazy
    basscrazy Member
    60
    right below are full details of what i got told
    Also someone has said the supercharger valve is the dump valve?
  5. h100vw
    h100vw Member
    218
    It's running well rich at idle.
    Have you had it scanned with VAG-COM? It gives a better idea of what's going on and usually points to suspect parts by name.
    It could be that the DV is broken but that's a 2 minute test and I don't see it making the car run rich.
    A faulty water temp sensor might or a massive air leak. Have a look on Ross-Techs web site about fuel trims.
    Gavin
  6. basscrazy
    basscrazy Member
    60
    yea it says exhaust supercharger recirc valve which is dump valve as its 50/50 atmospheric
    Other then that theve said temp sensor is working and the cat and lambdas are both new and the maf is new
    where is it running rich at idle tho?
    Mot standards are
    Normal idle 450-1500rpm
    CO no more than 0.5%
    im 0.2-0.3 on normal idle
    or am i missing something lol
