factory xenons retrofit
ru4shaw May 4, 2009
  1. ru4shaw
    ru4shaw Member
    222
  2. h5djr
    9,452
    1,765
    Do a search using OEM Xenons and you will find quite a bit of information already in this forum.
  3. NHN
    29,561
    1,778
    would depend on the xenon type tbh, the adapter you show is for the Bixenon adaptive, good luck finding them on ebay or cheap, the single vision xenons are plugnplay if you have halogen already & require coding
  4. mhill
    mhill Member
    323
    Why do people get so legally moral regarding the washers, IMO ive had two vag cars with them fitted and they are pants just squirting foamed up detergent on to the glass which then drys on causing far worse refraction.
  5. Khufu
    Khufu Well-Known Member
    5,704
    31
    I dont think its completely a moral issue, some newer members just plainly dont know that they are required and they run the risk of a potential CU20. TBH, I'm sure you right in the real world effectiveness of them.
  6. mhill
    mhill Member
    323
    CU20?
  7. Khufu
    5,704
    31
    thats general construcional use of a vehicle. Its like CU10 - brakes, CU30 - tyres, etc..
  8. ru4shaw
    ru4shaw Member
    222
    thanks for the reply but how do i go on about the recoding
    i got normal hologens and im goin for the single vision xenons and a projector for the diped and reflector for the main beam
  9. ru4shaw
    ru4shaw Member
    222
    and what about the bi-xenon is that the new shape xenons with the day time running lights and how much more work is that
    is there anywhere i can get this all done
  10. NHN
    29,561
    1,778
    Try not using fairy liquid next time, lol, mine have never foamed up, have worked perfectly aswell, funniest part of the car, but also functional
    See You Jimmy :undwech:
    You need either someone with VCDS to code for you or buy it yourself or when I get RT to answer me & help on pricing buy the cable from me for the software.
    Dont even bother about led ones, thats whole new front end cause different shape.
    But you can get 04-08 bixenons & also bixenon adaptives, requires more wiring for the both & knowledge does help along with some technical skills
