factory sat nav any good?
1animal1 Jan 6, 2008
  1. 1animal1
    9,978
    is it? seen them on ebay at between £100-£250, would imagine it looks quite good but is it any good....... think id miss the 6 disc changer in the symphony system....guessing the sat nav would have to utilise a boot changer instead......
  2. Cossie_boy
    Cossie_boy Member
    472
    Id never actually used Sat Nav until I got my A3 which had it in from the factory, but I must say I do like it a lot.
    I think a nice touch is that as well as the main colour screen showing the map, you get the display where the fuel computer is too, so when you approach a roundabout it show a little picture and which exit to take, as well as a little graph showing how near you are to the juntion.
    Quite impressed :icon_thumright:
  3. rickparmar
    rickparmar Active Member
    2,332
    14
    100 - 250
    you got any links mate
  4. steve1975l
    steve1975l Member
    595
    RNS-E would be my choice, didn't I send you the guide 1animal1?
  5. 1animal1
    9,978
    Cant remember you doing so Steve.....
    Rick, 1 went on ebay for £100 last night, not tested though so bit risky..... they tend to go for 250 if you go on ebay and search under 'Audi sat nav'
    Unsure as to whether it would utilise the DIS if im fitting myself.....presume this would need a reprogram...
  6. steve1975l
    steve1975l Member
    595
    You need Vag-com to do it properly.
  7. fingermouse
    fingermouse thats me
    4,031
    120
    prefer tom tom myself
  8. 1animal1
    9,978
    My mechanic is ex Audi, has the full original kit to do the job, thankfully
  9. steve1975l
    steve1975l Member
    595
    Fit the RNS-E then.
  10. Jimmeh
    Jimmeh Active Member
    1,438
    tim, did you ever go ahead with this?
    It's something i'm considering doing.. however, whether it's something I can do myself is a different matter... I read you have to trim the console down a bit for it to fit or similar?
    I have a 2001 facelift S3, single tape deck up front with CD changer in boot - would this house the RNS-E console or?!
  11. 1animal1
    9,978
    Na mate, didnt see much point in the end....im good with a map and hardly ever go anywhere else that would require a sat nav....looks good but its an expensive decoration
