Facelifts headlights to a pre face lift
Grale1 Apr 6, 2013
  1. Gops
    3,198
    666
    The lights will pivot inside, basically pull the inside of the lights up so the adjuster clip is closer to the outer casing of the light, that way you can clip it in! And cutting the wing is just trial and error. Cut little bits and refit the lights to see how they look should look like this:
  2. Gops
    3,198
    666
  3. Grale1
    Grale1 Active Member
    795
    44
    Mine just seem so tight to get it past the wing. I will get pics up, but there def not sitting in the wing properly, looks **** and think I need new wings unless I can't sort it a little more
  4. Grale1
    795
    44
    image.jpg image.jpg This is what it looks like from the front
    image.jpg image.jpg This is the view of each wing, it seems to be catching somewhere, I've cut a fair wedge out, you can see where it's not sitting properly at the wing.
  5. A3-Lee
    A3-Lee Active Member VCDS Map User
    938
    226
    43
    You need to completely cut the metal bit off completely mate the adaptor loom is easy to make tbh and you may find you need to tap the bottom of the wing down a bit hope this helps ... If you lived closer I'd do it for ya lol
  6. Grale1
    795
    44
    Ok cheers matey, maybe ill have a better look at weekend if its not slashing it down, I bought a adaptor cable of eBay for the loom as I didn't want to cut anything lol for the £35 they work perfect
  7. Grale1
    795
    44
    Seeing as it wasn't raining this morning I set about seeing if could do anything with the lights, I got them to fit a lot better, had to trim a little here and there and they went back in much better and sit better also so happy now, def make the car look newer
  8. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    You need to just keep cutting untill they fit snug. once they do and there in tight thats it they wont go anywhere!
