Facelift S4 rear bumper
Foxmeister Oct 21, 2009
  1. Foxmeister
    Foxmeister Fired Up!
    1,785
    Just wondering and checking b4 I go to fit it, sure I read somewhere b4, but does the standard a4 rear bumper side mounts differ to late s4 bumper? If so, does anybody have part no.s for them? Cheers.:icon_thumright:
  2. Lee Goodall
    Lee Goodall Active Member
    2,279
    Have a look on vagcat.com mate.
  3. Broken Byzan
    13,235
    464
    Deffo need the correct mounts for the qtrs.
  4. 951
    951 Member
    530
    I put a facelift s4 bumper om my pre-facelift (98.5) a4 and the side brackets fit the new bumper fine.The only issue is the facelift s4 bumper has a bigger bottom lip so the pre-facelift exhaust tail pipe will sit well underneath the bumper !!
  5. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    951 could it possibly be the same mounts as yours is an avant?
  6. Broken Byzan
    13,235
    464
    Thinking about it i went from a facelift bumper to the s4, so its possible that prefacelift mounts are the same as S4 mounts
  7. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    my facelift A4 fit the facelift S4 bumper (not that it helps you, thought it may eliminate one option)
  8. Foxmeister
    1,785
    Cheers guys, will have a look at bumper and standard clips/bumper to see if they do match first when I get back.
  9. aragorn
    17,889
    689
    The S4 is a prefacelift bumper on all cars, it didnt change at all when they went to facelift.
    As such, prefacelift side mounts are the same as S4 ones.
  10. rasA4
    3,287
    119
    hmm not sure about that aragorn, what do you mean the bumpers didnt change?, cosmetically? both front and rears changed IIRC
  11. 951
    951 Member
    530
    That would make sense as my s4 bumper's were both off a facelift car and both fit on my pre-facelift car using the original brackets.S4 bumpers are the same post/pre facelift apart from the rear lower lip is bigger on the facelift and i seem to recall the front grilles or foglights were slightly different or something like that ??
  12. aragorn
    17,889
    689
    d'oh, i didnt notice "rear".
    The fronts are all the same. The S4 didnt get the recessed washers etc that other facelift cars got, becuase the bumper didnt change afaik.
    Not sure on the rears though, as you say its defo different cosmetically.
  13. rasA4
    3,287
    119
    yes, 951 front fogs are smaller along with different lower grilles,
  14. aragorn
    17,889
    689
    Interesting.
    The bumper itself is the same part number, so presumably they only changed the grilles and fogs.
  15. rasA4
    3,287
    119
    yep just the grilles and fogs, for the front i would say!
    S4 Pre face front
    S4 Face front
    S4 Pre face rear
    S4 face rear
  16. 951
    951 Member
    530
    Typical after looking at the two different types together i prefer the pre-facelift !!
  17. Drizz
    Drizz Project Plush
    681
    is 8D0 807 683 G/ 3FZ facelift or pre?
