Facelift rear lights, plug and play?
LeeT Aug 13, 2011
  1. LeeT
    LeeT Member
    429
    As per the title, im going to fit some face lift rear lights to my 99 S4 avant tomorrow. Im sure ive seen mention of swapping pins over etc? Will they just plug in and work or do i need to swap pins about? Details of which pins would be good if that is the case as im strapped for time tomorrow
    thanks ..lee
  2. Oranoco
    Oranoco Well-Known Member
    3,799
    349
    I would assume you will need to do the pin swap in the plugs like you do with the saloon.
    If the same the swaps are
    O/S - Swap Blue/Red with Black/White
    N/S - Swap Blue/Red with Black/Green
  3. LeeT
    LeeT Member
    429
    thanks mate, which lights is it that needs swapping over? my reverse looks in the same place. im sure i'll work it out when i actually look at it but all the info's good so i can get it done quick
  4. Oranoco
    3,799
    349
    That's for saloon, double check before changing any wires. I've only performed the swap on my current one, never bothered on my old avant
  5. aragorn
    17,956
    701
    Avants are a streight swap.
    I might be interested in your old lights if they're in good nick.
  6. LeeT
    LeeT Member
    429
    Pretty sure they are perfect. Ill get them off after work and take a look
  7. LeeT
    LeeT Member
    429
    Well that was easy
    before
    After
  8. LeeT
    LeeT Member
    429
    Oh and a pic for you Aragorn
    They are nigh on perfect. Open to offers, not looking for much
