Facelift rear light help
kaliber Oct 13, 2009
  1. kaliber
    kaliber kaliber
    29
    guys i know this has been dun to death....but if searched everywhere 4 the post.
    basically i need a guide to replace my old rear lights to the new 09 ones i got yday. just bulletpoints would do...
    cheers
  2. Ash B
    Ash B Well-Known Member
    5,831
    85
    3 door or sportsback?
  3. LiAmR
    LiAmR New Member
    if u've got the 3dr just follow the instructions in manual to change a bulb (you have to pull the full light unit out to do this). Disconnect the old one and plug in the new, simple as that. Just watch the plastic cover in the boot covering the screw (i've got one loose behind the trim somewhere now!!)
    5dr I think needs programming tho...
  4. kaliber
    kaliber kaliber
    29
    sorry mate its a 3 door... nice car btw
  5. Ash B
    5,831
    85
    Didnt see you were new :sign_welcome: to the forum.
    And thanks. As already said above its only a 10min job and quite easy. Just unscrew the old ones and screw the new ones in. Just plug and play :)
  6. kaliber
    kaliber kaliber
    29
    thanx guys
  7. crypric23
    crypric23 Never satisfied
    586
    :sign_welcome:
  8. anty
    anty Member
    66
    is there a guide for the sportback ?
    i am also interested in sorting this out
  9. crypric23
    586
  10. anty
    anty Member
    66
    from kufatec's website, it says not suitable for RHD....
    and so i need to buy a vagcom too if so ?
    cheers mate !
  11. andyb_88
    andyb_88 Member
    101
    rear lights are tricky to get out, but keep filding and moving them bit by bit and the eventually do come out... I managed to do it without a guide/help in about 15mins - its pretty easy
  12. Johnny Bravo
    Johnny Bravo 6+1 Gears Audi A3
    898
    70
    I've bought mine from kufatec and I don't see why they say they are not suitable for RHD since on the both sides there are the same lights. The ones for 3 doors are indeed for LHD.
    The ones for sportback, both have the fog and reverse light so...
    After fitting, in order to make them work correct you need to do the following coding using a vagcom:
    Code:
    central electronics
    coding
    help with long coding
    Btye 9 to Dec = 0 - as the final brake light
    Byte 10 to Dec = 0 - Fog lamps as a taillight
    Byte 12 to Dec = 36 - dimming rear standlight
    Byte 19 Bit 2 Cold Diagnosis rear active - this must be activated
  13. crypric23
    586
    I have the exact lights from the link i put up , and my car is UK right hand drive.
    They are fitted and coded.
    Not sure why kufetec say not suitable RHD.
  14. pdargan22
    pdargan22 New Member
    25
    hi guys im looking to get the facelift rear lights for my 3dr, where is the best place to get them?
  15. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    Audi directly mate.
    BTW guys there's a thread linked in the FAQs all about these lights. Both 3 and 5 door.
  16. NHN
    29,561
    1,778
    Johnny, I have got my new SB lights working with my wiring & they work fine, but I'm just curious of a few things & I'm playing with mine a little & seeing whats possible before I seal the babies up, so any chance of some info please:
    Whats your long coding presently for module 09
    How do your rear clusters work, as in when you brake what lights up, what is used for parking lights the ring or bulbs
    Do your led rings work when you brake aswell
    Do the 2 outer light bulbs that are in the middle of the led ring get used now & if so for what
    Your kufa loom, where did the spare loose wire have to be wired to as I notice pin 4 of these isnt used which powers the ring inners, so must be using an existing feed in the boot lid for inner rings
    Thanks in advance.
  17. flippin82
    flippin82 New Member
    26
    Will the LED light from Kufatec to my 2005 3-door fit and work without coding? Anybody tried this?
