Facelift headlight question (FL car)
Bradderz_1988 Nov 24, 2012
  1. Bradderz_1988
    3,995
    262
    I have a set off facelift lights that are like new as the old ones are fairly dull so thought id replace them so it looks a bit cleaner now one off the lights has no adjuster motor how easy are they to swap out from my existing lights to the newish ones ??????
    Also got tge steering rack which will be going on today hopefully dont have the part number of it yet as its in packaging and quite manky with residue fluid but this one has no damper =)
  2. Bradderz_1988
    3,995
    262
    No reply needed as ive sorted it after a bit off poking and twisting lol
  3. Bradderz_1988
    3,995
    262
    Well got the headlights on and my god what a difference a set off clean clear lights does to the apperance and overall beam output of the car it look miles better glad i did them !!!
    Here from a while back -
    heres the manky dull n/s one -
    and heres the shiney clean o/s one -
    the o/s one is a depo light so is presumably not from 2000 but the n/s one is more or less same condition overall happy with the swap.
  4. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,166
    1,126
    Looks good mate.
    How did you get on swapping the motors over?
  5. Bradderz_1988
    3,995
    262
    The motor twists out then you have to push the motor at the top to pull the rod out from the headlamp as it sort of slots in a groove pretty easy when you look at. Going to tackle the rack this week sometime off work thursday/friday so may ask the boss if i can do it in works time save me wasting another saturday morning/evening as im not in work saturday.
  6. ScottD3
    15,166
    1,126
    I often thought about using the motors from my PFL lights in the FL lights.
    Rack?
    Fast rack?
  7. Bradderz_1988
    3,995
    262
    The steering rack is from a x reg TQS so has no damper where as mine has a damper the part number on it is 8d2 422 065 p. as the rack has play in it which is causing my steering to have a play spot so i constantly find myself making constant little adjusments with the steering wheel theres nothing in the uj so its pointing to the rack as ive just replaced all the control arms/TRE so finger crossed it will cure my problem and give me a bit better steering with the none damper rack.
  8. ScottD3
    15,166
    1,126
    Damper?
    We got dampeners in our racks?
    Possible being a bit silly and simple.
    What do they do?
    its is across the range or a TQS thing?
