Facelift console,have i got everything ??
951 Mar 7, 2009
  1. 951
    951 Member
    530
    I picked up the console including climate control/rear cage,drivers lower dash trim with headlight switch,rear part of console,switches plus all plugs and the hazzard control box. The only things i think im missing are the hazzard switch,gear lever boot and a piece of carpet trim that fits behind the cigar lighter. Have i got the correct control box and will the pre facelift gear lever boot fit ??
  2. Broken Byzan
    13,237
    465
    That looks about right to me. The only dfference from that to mine is i went double din.
    The boots are different as they clip in with the plastic bottom trim. I will look for my wiring diagram for the fogs etc
  3. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    i made a bit of carpet trim to fit by chopping up the old big peice, and pretty sure shift boot can be made to fit, if not ive got a spare?
  4. 951
    951 Member
    530
    Good idea about the carpet,dont suppose you have a spare hazzard switch as well ??
  5. frankiejr
    frankiejr Member
    53
    Do you have to replace the whole console or can you just replace the centre 'inner' section?
  6. Broken Byzan
    13,237
    465
    The whole lot needs to be changed as its all different sadly
  7. frankiejr
    frankiejr Member
    53
    Will give that a miss for a while then :(
  8. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    nice find 951 how much did you find this little lot for?:readit:
  9. 951
    951 Member
    530
    I paid £40 for the lot including the heater module for the drivers door lock ,plus the option to go back for any small parts i may of missed (for free) !!
  10. rasA4
    3,287
    119
    thats a bargain! was it from a scrappy? im after the outer centre console, handbrake console under steering wheel and glovebox in black as mine is in grey must be in very good condition though.
  11. voteforpedro
    voteforpedro Member
    632
    They've got a facelift with complete dashboard, centre console and airvents in Bill Way's in Cardiff, if anyone is local and cares... :)
  12. voteforpedro
    voteforpedro Member
    632
    How big a job was the wiring, including the air vents???
  13. Siena
    Siena Active Member
    2,626
    I was going to go the facelift option, but have decided to attempt fitting the B7 complete dash, still sourcing parts.
  14. voteforpedro
    voteforpedro Member
    632
    lol, trust you to go OTT. :p
    You didn't answer my email! Did you fit two N/S B6/7 wiper arms in the end? If so, could you take a photo of the new look for me??? :)
  15. Siena
    Siena Active Member
    2,626
    ^^^ Sorry about that.
    Still haven't gotten round to fitting the second n/s arm yet, have had my hands pretty full recently.
  16. rasA4
    3,287
    119
    too far mate anyway just want the bits i mentioned as mine is a facelift already.
