Facelift Climate control Unit
Zorty Jun 18, 2012
  1. Zorty
    Zorty Member
    47
    Hi All
    i have just installed a DD cage into my A3 (with great pain stacking time) end results excellent, with the cage i bought the facelift HVAC (Cliamte module) and was looking on here that the air con dont work. am not bothered about the air con as this country dont have temp over 20 anyway apart from the air con will it cause any issues with my car.
    thanks in advance guys and gals :)
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    the fans will stop blowing from the dash eventually in auto mode, due to a different cam system
  3. mike foster
    3,967
    Take the front panel off the facelift version and fit onto your existing module. You only need the plastic bit to fit snugly in the new position.
    If you then fit the single din front panel to the facelift one you can sell that as a facelift single din climate control unit !!!
  4. Zorty
    Zorty Member
    47
    u make it sound so easy lol
    have you done this mod
  5. NHN
    29,594
    1,782
    You cant just swap the parts over, its not that simple, plus the econ/ac buttons are reversed so would appear wrong.
    As Phil states, its not the aircon as such, just in general the motors & air direction thats disrupted & this is only noticed when you chnage the settings on the climate so would appear normal to most until a change of direction.
  6. mike foster
    3,967
    I've taken the front off a double din 2007 unit and put it on a single din 2006 unit. Donor double din was from a 1.9 tdi and mine is a 2.0 tdi. When I first swapped the whole unit over all the airflow systems were wrong. Seemed like the logical thing to do !
  7. mike foster
    3,967
    Whoops !!! Maybe not possible with the facelift then - sorry chaps !
  8. NHN
    29,594
    1,782
    You can do this on units that use the same heater type systems, but not mix//match between, although someone figured out how to swap the dials across with some plastic modding.
  9. PH1L
    PH1L Gievf Buckets
    3,851
    40
    as nigel states, ive been staring at a prefacelift looking into bits to transplant the facias but its not only a pia it involves quie a few hours of soldering im going to give it a miss
  10. Zorty
    Zorty Member
    47
    thanks chaps. so its more then just a air con issue then o well :( al wack it on ebay.
    what can i use to trim down my old climate unit to fit double din...
  11. NHN
    29,594
    1,782
    Dremel & masking tape.
  12. Ash187
    7,522
    759
  13. Zorty
    Zorty Member
    47
    Thanks Ash :) will have to do it sometime this week lol.
    first i need to cut down my climate unit. is there anyone in the yorkshire area that has done this before who is willing to do mine.
    will pay or buy u lunch in McDonalds and Mcflurry for Dessert hahaha :)
  14. PH1L
    PH1L Gievf Buckets
    3,851
    40
    worth trying to source one they come up cheap on ebay often
