facelift chrome climate control switch
Ash187 Oct 18, 2011
  1. Ash187
    7,496
    744
    hi guys,
    i am trying to find a thread that was posted here a while ago about swapping just the switches on the prefacelift climate unit to the chrome switches from the facelift version... not the complete unit.
    i have just spent over half hour looking but i cant seem to find it... can anyone point me in the right direction for this thread?
    i want to check whats involved in it and see if its worth doing it.
  2. Ash187
    7,496
    744
  3. 1inchpunch
    1inchpunch Member
    451
    I thought about doing this recently but decided that buying a whole unit just to junk it was a too much for me. I'm pretty sure one of the other posters on here with a white S3 stripped his AC unit to carbon wrap the front so he'll know exactly how to take it apart and put it back together. I remember seeing the pics of the unit stripped down and that's what started me thinking about doing it.
  4. Ash187
    7,496
    744
    well i also found this so hopefully i can make some sense of it...
    Google Translate
    i have just upgraded the headlight switch and have the vents and gear stick on its way so the climate unit and then window
    switches are on the list to complete project chrome!
  5. 1inchpunch
    1inchpunch Member
    451
    Did you change the whole light switch unit or just the switch itself? That's another one I've thought about doing but I only have the 3 stage switch and I think all the chrome ones are 4 stage so again I'd just be buying to rip the knob off (ooerr).
  6. Ash187
    7,496
    744
    no i did the whole switch but thats as i have retro-fitted the car from standard poverty halogen lights to bi-xenon headlights with auto function and drls :)
    basically from this
    to this:
  7. Khufu
    Khufu Well-Known Member
    5,704
    31
    I too wondered if its possible just the remove the centre part of the headlight switch but cant see how it comes apart.
  8. Rob-Quattro
    Rob-Quattro Member
    225
    13
    The new switches setting you back much "Itwasntme"? I'd love the new light switch (exactly the same as your new one) and the window switches.
  9. 1inchpunch
    1inchpunch Member
    451
    The rotating part of the light switch on the old style light switch just pulls right off so i'd imagine the new style chrome one is exactly the same and should fit as long as the diameter is the same.
  10. Ash187
    7,496
    744
    the light switch cost £64 from Dave @Stoke Audi.
    i have found a whole load of info on the climate switch but from what i can understand i would need to get the chrome part from a facelift climate unit... thought i would be able to buy them on their own and then fit them in :(
    Google Translate
  11. Baffles
    Baffles Active Member
    229
    44
    So did anyone come to the conclusion if you can actually just change the switches on the climate control unit without changing the face plate? On the pre-facelift unit you can just pull off the front of the switch - so I don't know if the new chrome facias would just click back on?
    I know that the new chrome headlight switch does fit on the pre-facelift car as long as you have the same functions, as in Auto etc.
    And lastly - check this out:
    Notice that this single din unit (from a US car) has chrome switches? I'm not planning to upgrade to RNSE yet, so these could help spruce up the interior a bit - cos I hate the stubby black ones we have. Anyone know the part number for these and if we could get them here?
    Cheers,
    Chris
  12. Ash187
    7,496
    744
    no its not as easy as that.
    here is a guide sent to me by the German dude that did the retrofit for the switches, he speaks of pictures which can be seen here:
    183050-735-551 : Drehregler am Klimabedienteil gegen FL tauschen : Audi A3 8P & 8PA : #203359946
    and his blog here:
    Google Translate
  13. N8
    17,163
    718
    Good thread and good work.
  14. Baffles
    229
    44
    Yup that's a great help. Will look out for a facelift climate unit on eBay then and (possibly) attempt it myself.
    Anyone know about the radio round switches?
  15. ps44u
    ps44u Member
    57
    Ash, was that a straight forward job? i also want to have the drl light switch, iv got the leds in but not the switch
  16. Ash187
    7,496
    744
    the light switch? easy to swap but need to rewire in the DRL switch.
    also if you had manual headlight adjusters then you need to disconnect these.
    the climate console? not done it yet mate... just put up my research but will be doing this mod very soon.
  17. Kevin A3 Quattro
    Kevin A3 Quattro 2008 A3 3.2 S Line Quattro
    41
    so ive searched and searched and cant find an answer- i have a 2008 and was looking into updating to the chrome switches. On ebay there are units for $200usd that are used. I have read that if you have a 2007 you cannot swap the unit over, however, would i be able to directly swap the unit into my 2008 S Line?
  18. Ash187
    7,496
    744
    on a 2008 you should be able to just swap over the complete unit and it should work fine.
    Kevin A3 Quattro likes this.
  19. Kevin A3 Quattro
    41
    awesome- thanks for the info!
  20. peaky83
    peaky83 Member
    60
    9
  21. Kevin A3 Quattro
    41
    ash- i tried to remove my headlight switch by pushing it in, turning and pulling but it does not seem to grip enough for me to pull. It sounds like a clip may be broken. Do you know how i can remove the headlight switch by going through the fusebox?
  22. Ash187
    7,496
    744
    There are 3 8mm bolts holding the panel onto the underneath of the steering wheel. On you can see on the side by the fuse box, the other 2 are under the panel above the pedals (on each side) remove these and then pull the panel away from the can and the light switch can then be removed. There are 2 small notches holding in the switch to the panel so press these in and it will pop out.
  23. Mike X
    Mike X Member
    151
    13
    Anyone got any info on the radio buttons yet ?
  24. pburv
    pburv Well-Known Member Team Glacier Gold Supporter Audi S3 quattro saloon DSG
    5,188
    10,859
    Hi Mike x. Just search for audi radio knobs on ebay and you will find concert volume knob in chrome for £18.99 oem one,s I think...I can only find the volume knob only:meeting:
  25. Kevin A3 Quattro
    41
    thanks for the info- ordered a facelifted switch- also was able to update my climate control with the TT version- thanks! Need to update my shifter
  26. Mike X
    Mike X Member
    151
    13
    Nice one , thanks pburv .
