Facelift Bonnet removal
PaulJC84 Sep 24, 2012
  1. PaulJC84
    PaulJC84 Owner
    2,914
    17
    How easy is it to remove the bonnet on a facelift A4?
    The bonnet arm bolts like easy enough along with the supporting leg. Its the washer pipes I am curious about.
    I am needing to get the bonnet painted and am thinking it may just be easier to get it painted fixed to the car.
  2. tonya4
    tonya4 TDi Powerrrr
    408
    The wiring is easy,so are the washer pipes,though I broke the lug off one of the washer jets when removing the pipe.It may be better to cut the pipe off.The bonnet strut is just a clip.
    hth
    tony
  3. CraigG
    CraigG Member
    190
    i imagine they could get a better colour match painting it on the car?
  4. PaulJC84
    PaulJC84 Owner
    2,914
    17
    They have the other front panels already so was thinking they could match the bonnet against them?
  5. brasiliangringo
    brasiliangringo Member
    626
    10
    I am no painter, but i do know that a proper job involves blending the panels which requires everything to be in place.. That is if you want a proper finish that does not show from panel to panel.
  6. PaulJC84
    PaulJC84 Owner
    2,914
    17
    Hopefully works out ok, I thought removing the panel would give a better coverage and make it look more like it had not ever been sprayed. Fingers crossed.
