facelift bonnet on pre-facelift B5?
riverstyx Jan 11, 2011
  1. riverstyx
    riverstyx New Member
    9
    Hi,
    Does anyone know if a facelift bonnet will fit a pre-facelift car? and if so what other parts would I need to change?
    Thanks...
  2. aragorn
    18,139
    765
    My facelift (the shed) has a PFL bonnet fitted, so i'd imagine it would just bolt right on.
  3. riverstyx
    9
    Ok, I know from searching for info that the front slam panels and the part of the bonnet catch that is attached to the slam panel is different between facelift and pfl but wasn't sure if the part of the catch attached to the bonnet was different too... Hopefully it'll just mate nicely with my pre-facelift bottom half...
  4. Foxmeister
    Foxmeister Fired Up!
    1,785
    Also, facelifts dont have washers on the bonnet, they're on the scuttle!
  5. tonya4
    tonya4 TDi Powerrrr
    408
    are they?Both my facelifts have the washers under the bonnet.
    tony
  6. riverstyx
    9
    Ah, I had read that they were under the bonnet and had taken that as meaning they were attached to the underside of the bonnet. If that is not the case I will have to rethink my plans.
    My girlfriend had an accident in the car before Christmas, the insurance company have written it off but we have bought it back as cat c salvage. Having stripped the front end last weekend it just needs a new bonnet, a new bumper, and two new headlights, plus a new air-con condenser. I thought I'd take the opportunity to fit a facelift front bumper with fogs and facelift headlights and figured if I was doing so I might just as well fit a facelift bonnet too if it was a straight swap. The car didn't have front fogs at all before so I'll need to get hold of a switch and possibly install the wiring/relay etc if there is no existing loom.
  7. aragorn
    18,139
    765
    They are attached to the underside of the bonnet.
    I think my slam panel might have been changed too, so no guarantee those bits will mate up.
  8. tonya4
    tonya4 TDi Powerrrr
    408
    whereabouts are you mate?I'm breaking a facelift avant at the moment
    tony
  9. riverstyx
    9
    I'm down in Devon (Exeter to be more precise). I've already sourced the bumper & brackets, and the headlights, but still need a bonnet (and air-con condenser - although I think the hose connections on the later condensers are different so probably best stick with pre-facelift for that)
  10. Foxmeister
    1,785
    Correction-They are under the rear of the bonnet, my mistake!
  11. tonya4
    tonya4 TDi Powerrrr
    408
    I'm in barnstaple mate,north Devon,and have a facelift bonnet and the aircon bits you need.
    tony
  12. riverstyx
    9
    Thanks Tony - I've sent you a pm.
