F***ing car
S3featesV9 Apr 10, 2012
  1. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    Um old, recently sorted all paper work for my car and didn't see anything about a new one.
    Probably a good shout though, cheers mate! Where's best for one of those, Audi I'd guess?
  2. badger5
    9,633
    2,071
    I have seen CC maps do that boost.. and some that have'nt...
    higher flow intake combined with a high initial boost spike does cause surge.
    option are clamp the spike with an mbc in parallel or remap to one which does'nt spike
  3. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Yeah, Audi or TPS, I bought one last year and it was about £40+Vat-ish.
  4. S3featesV9
    1,032
    12
    Remap, could do with a new one anyway as I'm pretty sure its running quite lean. Which killed my turbo initially.
  5. badger5
    9,633
    2,071
    CC do not run lean... ever.. Hardware issue if it really is running lean.
    Have you got logs of its fueling?
    tired fuel pump perhaps?
  6. S3featesV9
    1,032
    12
    No logs bill. Will get some done Monday. Fuel pump is 10 yrs and 110k old though, so possibly. Will have to book in with you and get things checked over, and remap if required.
    Sometime after the 15th of June though if possible.
  7. beachbuggy
    beachbuggy Well-Known Member
    1,931
    202
    Are you running a hybrid? I'd be very surprised if its surge with a stock k04, is that possible.. Can they flow enough to surge.
  8. S3featesV9
    1,032
    12
    Not a hybrid. Brand new standard k04-023.
  9. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Mine does it on a standard k04, I believe there's quite a few others too.
  10. S3featesV9
    1,032
    12
    What's your plan to overcome the surging?
  11. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    may aswell get a new map imo. both of you.
    the maps you have were obv fine for your regular silicone tips and filters, but the b5 tip is THAT good it doesnt need all that boost (which is alot) to make the power.
  12. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Current plan is to fit the downpipe, cat and milltek I've just acquired, together with a FMIC to help overall flow and see if it helps. If not then I plan to reduce the load settings in the current map via unisettings. If all this fails then a new map may be on the cards.
    Mine was mapped with the B5 TIP already fitted.
  13. beachbuggy
    1,931
    202
    Problem with unisettungs is that you take load off the while map, therefore you resurgeries down low to overcome surge but will also reduce load up top as well which what you don't want . You need to reduce load specifically down low, leaving top. End as is.
  14. badger5
    9,633
    2,071
    yes they can and do in some installs............. particularly those which spike initial boost on spool up.
    a cheap(ish) DIY fix, without need for remap is add an ball/spring type mbc in parallel with n75 and use that to clip the spike.
    forge unos for example been used for this, works well.
  15. S3featesV9
    1,032
    12
    Think I'll give that unos mbc a try then. If I have room around the tip, bare space there. Or is there somewhere else to instal it?
    Also I take it that it'll be just trial and error to get it set up correctly? Never used a mbc before so all new to me
  16. badger5
    9,633
    2,071
    yes trail and error..
  17. Rosso TT
    Rosso TT Member
    146
    I though i put it out there.
    Could be that there's exess preload on the actuator not making the WG creep at low boost?
    On my car (TT225) with n75 electrically disconnected i get around 6 psi of boost.
  18. S3featesV9
    1,032
    12
    I'll wait and see and what this forge mbc does. Haven't ordered one yet. Keep swaying from that to a remap. Surely it would only need tweaking? Or will I require a whole new map?
  19. badger5
    9,633
    2,071
    CC map is CC's.....
    not whole new map, but CC would need to alter "their" settings..
    MBC will be cheaper for you
  20. S3featesV9
    1,032
    12
    Not something you can do then bill?
  21. badger5
    9,633
    2,071
    not to CC no
    to my own of course
    as i have already said, cheapest for you is mbc in parallel to curb the spike you dont want
  22. S3featesV9
    1,032
    12
    Yeah I no what your saying, is it an as good idea as a remap though? What would you recommend if price was irrelevant, remap it or just cap the spike with a mbc?
  23. badger5
    9,633
    2,071
    cap would be as effective........ does the same thing.. reduces that initial spool
  24. Maverick1
    Maverick1 Member
    49
    So who ended up fronting the cost of the rebuild?
  25. S3featesV9
    1,032
    12
    I payed for new crank, £390, and new arp bolts for rods. Garage did the rest.
    We arranged that I'd pay for parts. They would do consumables and labour. Whatever the consumables are.
    If I was to get them to pay whole amount, I'd need a external vehicle assessor to do a written report and inspect car. Which costs nearly £300 and can take a month. And then the garage may want to take it to a small fee court. So just more hassle.
    Bit of a s**t situation tbh. Am glad it's
    Over. It really is worth going further afield and going to a respected garage for work like I had done.
    Lesson learnt!!
  26. Maverick1
    Maverick1 Member
    49
    Spewing. At least you came to a compromise that didn't completely screw you over. Glad to hear it's now behind you.
