F***ing car
S3featesV9 Apr 10, 2012
  1. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    Cars gone again, lost oil pressure and engine knocking AGAIN. Really at my
    Wits. How much is the s3 worth needing new big end bearings? Lol.
    All I can do is laugh, otherwise I'd cry! Stupid arsing **** 1.8t engine.
  2. aragorn
    18,135
    764
    Screams of incompetent workmanship to me!
  3. S3featesV9
    1,032
    12
    Yeah pretty much. Just not sure if it's the garage at fault or place that reworked the crank and supplied new bearings.
  4. Dani_B19
    9,163
    360
    Gutted for you mate.
    Hope you get it sorted.
  5. <tuffty/>
    20,997
    3,764
    I have to agree with aragorn here mate... have built a few of these in the past with no issues... you had the crank reground didn't you?
  6. ci-ryder
    ci-ryder Member
    199
    Wow, you are certainly not having an easy time of it. Hope you get some joy out of the garage who did the work and don't have to pay to get it sorted again.
  7. S3featesV9
    1,032
    12
    Yeah had crank reground. Livid at the moment.
    It could be something else, but I am pretty sure it's bottom end. it has a brand new oil pump and oil pick up. Well is supplied them, so hopefully they were fitted. So just doesn't add up. New bearings, crank fresh, new oil bits mentioned, new forged rods, rifle drilled. New piston rings, new valve stem seals. New cambelt new pulleys, new everything!!
  8. aragorn
    18,135
    764
    Point is even if the engineering shop that reground the crank messed it up, the folk building the engine should have plastiguaged it to check all the clearances before putting it together, especially after the first failure, everything should have been triple checked.
  9. S3featesV9
    1,032
    12
    True. Manager of garage isn't in today so won't here anything until mid day tomorrow. Not having anyone else touch it.
    If something wasn't done right...surely this would of happened ages ago? I've done loads of miles. Like four tanks worth so about 1200 miles. Should all of this worth be covered by the garage? Or can they just turn around and bull**** then make me pay again?
  10. Benjiman46
    Benjiman46 R-Tech Terrorist
    551
    24
    Mate, that's rubbish!
    I guarantee though it's the place that reworked your engine and not the garage. Get in touch with them. Surely you should have some warranty after only 1200 fu**ing miles!
  11. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    Dude, bummer. Not sure what else to say. Keep us informed of any updates.
  12. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Mate this is seriously **** news! When I had works done by the garage you used they realy didn't fill me with confidence ant it was only a small job! I don't realy trust them at all. Just my thoughts though, if you are thinking of selling your car on you will probs be better off just breaking it to recoup most of your losses......
    If so I'll have your TIP lol!
  13. jojo
    28,856
    3,516
    The Vultures are circling already! :laugh:
  14. superkarl
    superkarl MAN OF STEEL
    9,423
    2,382
    bagsy the rods!
    thing is it will be hard to trace the problem and then you have the hassle of getting the garage/engineering place to admit fault.
    best of luck. no one likes to see a poorly 8l S3 die :sob:
  15. <tuffty/>
    20,997
    3,764
    Stripping the engine will tell you... I suspect looking at the state of the shells will indicate whats happened... thats where I would start looking... the other thing is if they have fitted the rods correctly... I have heard of garages not doing the ARP bolts up properly in the past doing the factory method (stretch bolts) which is not suitable for ARP bolts... there is a specific sequence for this...
  16. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Yep it sounds like the rod bolts have come loose to me and spun the bearings maybe....anyway whoever s fault it is i am gutted for you and the one thing i am dreading,, i hate stories like this 200 mile into running mine in...:sadlike:
  17. Customboy
    Customboy Member
    831
    42
    Buy a gun and all problems will be solved!!
  18. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Can I also suggest the Rod caps have been put on the wrong way round, Ie the tangs on the bearings and caps not facing each other. I've seen this before more than once, and althoug they go on the engine get will run they wear the bearing out in 500-1000miles just like yours. They issue you have is that if you take it back to the garage that did the work, you need to be there to watch them when they take it apart or they can easily say, oh we did it right and blag you! or get it inspected by an independant garage getting them to look very closely to the build and the way parts are put together.
  19. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    One word mate : Gutted :(
    I had issues with my last S3 and a clutch change which almost broke me whilst trying to get it sorted. Still after the effort and money taking to get it back on the road this is just another hurdle to overcome and from whats been said above by clever people sounds fair and therefore i believe you should be able to get it sorted by the people who were at fault.
    Rob
  20. S3featesV9
    1,032
    12
    ARP bolts? They used the bolts supplied with the rods. And yeah I have tomorrow off work now so will be over there as soon as end and crack are off to see it for myself.
    My dad has said it will be fixed whatever. He isn't taking any ****. He's had enough of it more than me. Even when it is fixed, it'll still may be put up for sale.
    Will have more info on it tomorrow. And yeah Matt, I wish I never went there in the first place. But as they did the work (horrendously) they can fix it.
    Really hope it is rods bolts come loose. What torque should they be? I'll ask them tomorrow and see what they say ;))
  21. Westy
    Westy Well-Known Member
    17,443
    1,103
    I'm now petrified. I'm only 20 miles into my bedding in process! :sadlike:
  22. Andy123
    Andy123 Member
    260
    The bolts supplied would have been ARP fasteners and should also have included the lubricant used to install them. There is a specific sequence you need to follow when fitting them, torquing them up and undoing them a couple of times IIRC to a specific torque and then finally torquing them to the required load. If they have cocked up any part of this or not even used the lubricant then you could have a bolt that has been torqued up too little or too much and has been stretched and won't clamp the rod and end caps together correctly.
    Good luck with getting it sorted mate, it's too easy for them to pass on the blame but perservere with it until it is sorted.
  23. <tuffty/>
    20,997
    3,764
    ARP bolts on the rods are normally torqued to 55ftlbs 3 times (3rd time being the final torque)... you apply a bit of moly based grease (IE rods come with ARP grease in a packet) as the bolts are hard and will give false torque readings as they bind on the rod cap... then tighten to 55ftlbs once... slacken off... torque to 55ftlbs again and slacken off then torque to 55ftlbs for the third and last time...
    OEM spec is some torque (can't remember figure) then 90 degrees iirc... fine for OEM stretch bolts, not so good for hard ARP ones..
  24. Westy
    17,443
    1,103
    Oh ****! How important is it to slacken off after the 1st and 2nd torque ups? We did mine 3 times to the torque setting specified but didn't slacken between each one. IT was the same way Stacey did his engine and the same Pete had done his so fingers crossed it will be fine.
  25. <tuffty/>
    20,997
    3,764
    ARP-bolts.com | ARP - World-leading Fastener Technology
    On ARP's correct lubricant and re-torque cycling is fairly important... they don't stretch like normal bolts and need to be done right... article above is quite general but will give you an idea...
    If you didn't use any lube at all then I would be more concerned... not using the recommended tightening sequence could mean the preload on the bolt is not enough and could cause the bolt to work loose over time...
  26. aragorn
    18,135
    764
    I did mine like you did Westy and mine hasnt fallen apart yet :p
  27. Westy
    17,443
    1,103
    The ARP lube was used yes :yes:
    Great news lol
  28. <tuffty/>
    20,997
    3,764
    Isn't that the same as saying 'I have a big turbo and std rods and mine haven't bent yet...'? ;P
  29. aragorn
    18,135
    764
    yeh probably :p
  30. Welly
    10,696
    127
    :lmfao:
  31. S3featesV9
    1,032
    12
    Great! Bet they did the OEM torque, if they did any at all. All was going so well too. Paynes who did the crank have said they are willing to inspect it all too see what's happened. Roger who has been in the business for 40 years said he has never had a problem. And guarantees the garage have messed up installing it. Thinks a bearing has slipped too.
    And that red grease, was still in the box when I picked it up. Opened but half ish remaining.
    Am hoping the rods aren't scarred. As they cost a fortune.
  32. Andy123
    Andy123 Member
    260
    Mate I don't get how you torqued them up 3 times without undoing the bolt each time and slackening them off?
  33. S3featesV9
    1,032
    12
    Maybe he was just triple checking they were torqued correctly
  34. Westy
    17,443
    1,103
    Correct. Wen round and made sure they all clicked on the torque wrench 3 times.
  35. S3featesV9
    1,032
    12
    I'm sure your have no issues any way dude. Garage I've used are just monkeys. Live and learn! Actually would of been cheaper for me to take 2 weeks off and do it myself after all this 'extra' work.
  36. sportstractor
    sportstractor Chugger
    2,709
    Uh oh westy, if I were you, I'd drop the sump and re torque them :p
    Bummer on the engine failure dude, that really is unlucky!
  37. Westy
    17,443
    1,103
    You don't need 2 weeks mate. All you need is the ASN Engine Response Team to come round an blitz it in 2 days. You just have to pay for their services with beer and curry ;)
  38. S3featesV9
    1,032
    12
    well if the garage refuse to pay and its coming out of my pocket then i will be doing it at home, so ill take you up on that offer!! poppadoms too yeah? haha
  39. <tuffty/>
    20,997
    3,764
    Just make sure you torque the rod bolts right ;P
  40. S3featesV9
    1,032
    12
    Just popped to the garage to see my car still sat outside not even touched yet. So spoke to the manager who did that work. I mentioned that I'm sure it's span a beating, he said he had started it up and built up revs to 1k and could here it. He agrees. So I asked why do you think this has happened. He said until the sump is off he can't comment why. So I jumped in and said the Rods were torqued correctly right? He just replaced with yeah to OEM spec. :( so explained that these are different and require specific settings. He said well, if that's the case they should of stated 'please torgue to x y z etc. so how was he to no. My comment of your the professional mechanic not me.
    What do I take as next step now? Assuming it is this?
