F*@@?: car jacks
Biglockie Feb 26, 2008
  1. Biglockie
    Biglockie Aye you know it makes sense
    1,032
    got a flat on sunday morning so blew the tyre up, drove home potterd around for a bit went out to the car and the rear tyre is down again, got the spare out, put the jack under lifted the car turned round to ge tht ewhell key and the bloody jack slipped dropping the car and pushing its self through the skirt splitting it and stretching the door trim beyond repair. Luckly no one was under the car and no one was hurt, so nee to ge tthe skirt plastic welded and repainted and buy a new door trim, the jack is now in a field somehwere behind my house, still dont know why it slipped the ground was dry and level.
    so please be careful guys
    *edit* anyone know where i can get a S4 door trim from? rear drivers side
  2. billybravo
    billybravo Active Member
    1,045
    no way thats a shitter i dont know where my std audi jack is anymore also it went in the bin when i stripped the car as i had never used it and never will.
  3. Biglockie
    1,032
    I'll try to get some pics on tonight.
  4. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    Same thing happened to me, luckily the wheel was still on and the jack didn't damage anything. It seems you really need to chock the front wheels as any movement, no matter how small, can be catastrophic, even putting the car in gear still provides enough movement for the jack to tilt.
  5. White220
    White220 White 220
    64
    This happenned to me too, with my MkV golf was so gutted it qued histerical punching of my tarmac driveway. Had some warranty to claim on other paitwork issue from an accident damage repair so they filled and resprayed the pierced sill (FOC) at the same time and you can only just tell if you already know about it.
    Buy a trolley jack and some axle stands if you're ever going to be underneath the car!
    D'oh!
  6. Biglockie
    1,032
    have got both of those but was just changin a puncture on the bloody thing, lucky the skirt is the only damage no sill damage
  7. macca
    macca Member
    525
    never use standard jacks that come with cars unless absolute emergency, use a good trolley jack and some axle stands everytime.
    i do feel for you though, as i have had a car slip of a **** trolley jack before.
  8. motorbikez
    motorbikez Active Member
    2,043
    Sorry to hear about that mate.Learn from your mistake and do as macca says get yourself down to halfords and get a trolley jack and stands.
  9. Markey
    Markey Active Member
    2,175
    trolley jack is worth its weight, but when i am using the normal car jacks u always put the wheel i have just taken off under the car for extra saftey.
    Glad you were not hurt mate that could have been nasty.
  10. Biglockie
    1,032
    Just booked it in for the weekend to get the skirt removed and repaired, need to track and door trim down the section along the bottom that sits on top of the skirt, any ideas??
  11. Markey
    2,175
    I think i got min from vag parts not that expesnive.
  12. Biglockie
    1,032
    I'll have a wee look cheers Markey
  13. Markey
    2,175
  14. Broken Byzan
    13,237
    465
    Different for the S4 tho, i bet that they aint £20 a door
  15. robbie5
    robbie5 NEVER ENOUGH
    102
    This also happened to me – the car was balancing on the front disc!!!! Thankfully
    all is still okay!
  16. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    absolute nightmare mate. Only ever used mine in emergency and had to watch like a hawk. Could see as it lifted the foot moving and twisting
  17. docurley
    4,073
    88
    Ouch..... I had something similar happen to me but I was lucky as I had put the wheel under the car so no damage and need less to say I bought something a little be more heavy duty.
  18. Broken Byzan
    13,237
    465
    Thats why its commonly known as "the widowmaker" design... Bloody things. Glad you ok tho Chris
  19. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    Try and get a trolley jack with a rubber pad on the saddle, doesn't remove any paint from the sill, which encourages rust.
  20. Biglockie
    1,032
    Just ordered a trolley jack online and investing in a set of run flats. I had luckly left the wheel on the car with two bolts still in so it didnt land on the floor just the jack slipped into the skirt. My missus came out just after it happened, as the jack way flying into the back field and made the age old mistake of saying "At least your ok ITS ONLY A CAR AFTER ALL" i went for a walk immediatly and returned about a half hour later LOL
  21. Markey
    2,175
    PMSL women just dont know do they....
  22. Biglockie
    1,032
    No idea at all fella
  23. Caesium
    4,879
    drop one of their lipsticks down the loo and then see what their reaction is....
  24. Biglockie
    1,032
    Dropped her mobile down the loo after a few beers, acidentlly of course that caused a war
  25. mattandrew
    mattandrew Member
    977
    21
    When i priced up the bottom door trim for an A3 8P drivers door is was about £16 from the stealers if thats any help.
    Matt
  26. Biglockie
    1,032
    I'll check the stealers fella might be worth it if its that cheap
