EXTREMELY annoying rattle from behind the speedo dials?
Ben S3 8P3 Dec 22, 2012
  1. Ben S3 8P3
    Ben S3 8P3 Member
    313
    32
    Has anyone experienced this or got a fix for the issue. It comes from the dashboard and sounds like its something behind the speedo dials that has come loose.
    It doesnt happen all the time but a pot hole can trigger it and banging on the top of the dash eventually sorts it temporarily
    (2009 S3)
  2. Geraldy212
    Geraldy212 Sportback owner
    565
    42
    Suggest you remove the instrument cluster, and disconnect the plug at the back. Get a bright torch and look around for a loose cable or other bit that needs securing. That should do the trick. Good luck.
