External Temp thermostat
imported_Smudge973 Dec 15, 2005
  1. Since Tuesday the external temperature guage has been reading between 9.0 degrees C and 12.0 degrees C - It definatly not been that warm - It was very frosty this morning and it was reading 12.0 degrees - Anyone had this before ? Where is the sensor located ?
    Cheers chaps.
  2. Merlot
    Merlot Member
    44
    Its 10c here at the mo.
  3. I would not see it as a problem, but no matter when I check it's always the same - Had to defrost the car this morning - it was very cold. Just had the car serviced on Monday - Only happened since then.
  4. imported_G4JSG
    imported_G4JSG Guest
    It's behind the front number plate, open the hood and you should see it.
    Temps seem to be same as over here.
    John
  5. Ok - I'll see how it goes for the next few days.
