Exterior door trim
rob v6 Jan 23, 2010
  1. rob v6
    rob v6 Learning the VAG way
    161
    evening how is everyone?
    does any one know if it possible to replace the trim at the bottom of the door (exterior) and how much it is either main dealer or else where or if something else can be fitted ie from a newer sline.
  2. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    Think front door is about £20 and rear about £15 from audi. you can get s4 ones but very expensive and wouldnt work right without the skirts etc. What doors do you need the trims for? Ijust took all mine off and they are ok,2 are about a year old.
  3. rob v6
    161
    all of them need replacing as the metal runner that is inside the strip has gone rotten and does not clip onto the door properley
  4. ian52
    1,199
    I'll check all mine later and see what the back of them are like. 2 I know are like new anyway.
  5. Oranoco
    Oranoco Well-Known Member
    3,862
    381
    Euro Car Parts do these and they are a bit cheaper than teh dealer and are a dealer part.
  6. tazzy baby
    tazzy baby Welsh & Proud
    569
    Funny you should say that mine are gone aswell on all doors and also the rear drivers door trim has gone to the one thats half way up the door any one know how much they are thanks
  7. Oranoco
    3,862
    381
    iirc they were about £18 each
  8. Road Razor
    Road Razor Member
    411
    They're prone to rust and rot from the inside. The replacement trims are a newer design made of hard plastic inside. There's quite a fair number of b5s I've seen with at least one of the trims removed, leaving behind a row of white clips.
    I've had all my door trims and clips removed, dremelled the studs, patched up the holes. All my trims were colour keyed, therefore it wasn't worth replacing a single trim and respraying it. It even looks better than before.
  9. tazzy baby
    569
    have you got any pics butty
  10. Road Razor
    Road Razor Member
    411
    The sills and door trims had already been painted. This is how it looks without the door trims & corner trims.
    Those holes in the corner will be patched up as of next week.
    This is how it looked before with the trims on:
  11. low610
    low610 Member
    125
    I've replaced some of my door trims from Audi direct, they're about £18 each.
  12. BigJimKnickers
    BigJimKnickers New Member
    15
    I need to replace mine too, is the £18 from euro car parts just for the outer trim? Or all the necisary parts to replace? Some donkey cock who owned my A4 has screwed the driver door one on with a self tapping screw!! Looks bloody awful.
