Extending the life of my A3 2.0 tdi, any tips.
paul_r Jan 16, 2011
  1. paul_r
    paul_r Member
    172
    Hi,
    I intend to keep my A3 2.0 tdi for many years to come and wondered if anyone had any tips to keep it in top condition.
    1. I clean it regularly and keep on top of any little problems.
    2. Service it on an annual basis
    3. Drive sensibly, letting the turbo spin down at the end of long journeys.
    Anything else. On my last car (BMW 316) i changed the oil twice a year. Is it worth it on the Audi. I do 10k per year.
  2. paul_r
    paul_r Member
    172
    No suggestions?
  3. audicruiser
    audicruiser Audi Heaven
    1,865
    Well you have sort of answered your own question within your question. As long as you do the things you say you'll do then your Audi should last years and many thousands of miles.
    Changing your oil annually will be fine at that mileage, just use the correct grade of oil and Audi normally recommend either Castrol or Mobil...
  4. Ash B
    Ash B Well-Known Member
    5,831
    85
    As scott said you answered your own question lol. Maybe warm it up and let it warm down.
  5. Joolz
    Joolz New Member
    20
    Id a 2.0 140 tdi quattro with 70k which i intended to keep for many years, i was goin to be changing the oil every 5k but not with the longlife oil. Changing this often would keep it runnin forever just about. Then i sold it!!
  6. paul_r
    paul_r Member
    172
    Thanks. I'm on annual service.
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    regular coats of waxoil to the underside and a coat behind the skins of your panels
  8. Gti Jazz Blue
    Gti Jazz Blue Active Member VCDS Map User
    1,655
    I'd say run an some Diesel addative in it too, one weak area with modern diesels is the variable vane turbo. The vane mechanism can get clogged up with soot resulting in requiring a replacement Turbo and possibly more if the Turbo goes pop. Fuel addatives can help keep the soot down and so delay that process.
    Paul
  9. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,321
    187
    My advice would be filters !!
    I used to run race bike engines on the track with velocity stacks which really wasn't a great problem because the engines were regularly striped. One of these engines i put in a road bike and after 10k miles it was totally shot !!, not through any fault of the state of tune etc but without air filters the bores were just worn away. minute particles of dust and sand, general air pollution destroys cylinder bores, rings and pistons in no time so always use a good filter and if you want mileage then a std paper filter is as good as they come.
    Secondly, Oil filters. It goes without saying that you need a good quality fully synthetic oil like Mobil1 diesel variety and an annual change...but don't just buy the cheapest filter you can get. That filter will be working hardest just before you change it when the oil is dirty so you want it on top form when you throw it out !!!. Don't play about with long life services. Oil picks up carbon deposits and is continually washing the engine picking up piston blow past and varnish deposits as well as minute particles of metal. Long life oils might hold viscosity longer but they get just as polluted with **** and fuel deposits as normal oils...... but you change that normal oil twice as often which has to be better !!
    In short, treat the inside of your engine as a precision instrument and it will last a lot longer mechanically. There is no reason why your engine should not cover 200k miles on its original bores and pistons if it is fed clean air and clean oil and clean fuel.
  10. paddy
    5,321
    187
    More good advice and well worth a few £ outlay IMHO
