Extending Glow Plug Time 2.0TDI in VAGCOM?
c_w Dec 5, 2010
  1. c_w
    c_w Well-Known Member
    1,163
    87
    I know it's a strange request but does anyone know specifically how to extend the glow plug time on the 2.0TDI engine? (170 to be specific). The first cold start of the day it usually fires up then dies straight away or takes longer than usual to start. The battery is fine and once it's been run for a few minutes it restarts perfectly.
    It's got new OE glow plugs on, new fuel, air filters and otherwise runs perfectly. I've found that if I put the ignition on, wait for the glow plug light to go off, then do that a couple of times then start it, it starts fine first time, so just wondering if I could alter the glow plug time a bit so that don't need to keep doing the ignition on/off first.
    In VAGCOM in Engine module / Adaptation, I think on channel 8 there is a setting that says 2 seconds at 0 deg, I think this is the glow plug time. The original setting is "128", but don't know what figure to put in there to increase the timing (have tried random numbers like 127/129/64/256 but it doesn't accept anything so left it back at 128).
  2. dunk
    dunk Member
    770
    it doesnt work on the 8P - i tried it on mine but nothing would make it change the real value
    only working solution i found was to turn on th ignition, wait for the orange glow light to go off, then turn off the ignition for a few secs, turn on again and wait again, then start engine.
  3. PH1L
    PH1L Gievf Buckets
    3,851
    40
    as dunk says it doesnt seem to work, but turning on and off will have the same effect
  4. c_w
    1,163
    87
    Ok thanks! I've been doing the igniton on/off thing, bit annoying but suppose sounds like have to just do that in this cold weather!
  5. cptn_molo
    cptn_molo New Member
    Have you had the injectors tested? i seem to remember poor starting can be a sign one is on the way out - something to do with loosing compression in one cylinder. My 2.0tdi has no issue starting cold
  6. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    Not much help i know but the glow plug time can be changed in the mapping if you have a custom map.
  7. basssound
    basssound Member
    203
    10
    I've got the exact same problem, leave the glow plug light on a few seconds, do this one or more times and then the engine refuses to starts on the first turn of the key.
    I have to try it a couple of times and also have the accelerator pedal pressed at the same time :(
    I've only had the car 9 days!!!
    Gonna start with a vagcom scan, replace the plugs, check for voltage drop on the starter motor, check for fuel running back to the tank and so on.....
