Expected Mpg 07 2.0Tdi 170 S line sport back DSG
paultaylor May 14, 2013
  1. paultaylor
    paultaylor Member
    294
    Hi All,
    I was wondering if members could post their real world MPG figures so I can compare to my wife's 2007 SB 170 DSG 48k miles F.Audi Service History
    It's a great car but with a 60% motorway 40% urban mix of driving it only get 430miles to a tank.
    Some things that may be contributing:
    The G450 sensor fault has been coming up for the last few weeks(tempted to just replace it)
    Only one active regen on DPF in last two years but the car idles at 900rpm which seems higher than before the mechatronics unit was replaced.
    Lately it takes 25 mins to get up to 90 degrees and coolant light comes on from cold starts only despite no drop in coolant(may have clean two pronged sensor or replace whole tank)
    It's a fantastic car that I nearly enjoy driving more than my 07 R32! only gripe is I feel the mpg should be better
    thanks in advance
    Paul
    p.s. some house beats for your car!
    https://soundcloud.com/killingpaolo
  2. A3Kent
    A3Kent Well-Known Member
    1,571
    249
    I'm getting 500miles from a tank and that's hardly doing any motorway miles at all. That's an 2009 170 Manual though.
  3. immo
    immo Stop me
    275
    40
    I get 530-550 miles to a tank, but that's nearly all 40-60mph roads commuting to work
  4. stetheo
    stetheo Active Member
    356
    108
    43
    I have a 3 door and I get 530-600 miles out of a full tank depending on how much town driving i do. All other driving is 60/70 on lanes and motorways to and from work.
  5. max69vk
    max69vk Active Member
    862
    57
    Round town driving expect as low as 360 to a tank :(
  6. paultaylor
    paultaylor Member
    294
    Sounds like I should be getting another 70-90 miles per tank!
  7. SCFC_Messiah
    SCFC_Messiah Member
    278
    14
    I have a 2006 170 manual with stage 1 remap. If I'm doing a long motorway run (usually Swansea to Carlisle and vice versa) I can easily hit 50mpg, sometimes 55mpg if I'm especially careful (that's religiously sticking to 65-75mph - anything over 80mph and my MPG drops away rapidly).... One the flip side if I'm doing 100% town driving with lots of short, stop/start journeys (with the odd fast acceleration :whistle2: ) I can drop as low as 30mpg average over the tank full. Quite a big swing
    I think that roughly works out around 650+ miles per tank on 100% motorway driving, but as low as 350 miles per tank on 100% city driving. I find your driving style has a massive impact on consumption too, more so with this car than others I've owned
    I'm no expert, but if you really are doing as much as 60% motorway driving, then ye, I'd expect a better return than 430 miles. Probably around the 500 mile mark. Unless your missus drives like Susie Wolff?
  8. paultaylor
    paultaylor Member
    294
    I'm no expert, but if you really are doing as much as 60% motorway driving, then ye, I'd expect a better return than 430 miles. Probably around the 500 mile mark. Unless your missus drives like Susie Wolff?[/QUOTE]
    LOL, she mainly just goes to work at a steady 60-70mph on motorway so I'll start looking at ways to improve MPG, DPF delete being the obvious choice.
  9. davesimmo
    davesimmo Member
    180
    13
    Mine has never been less that 500 and I don't drive like a fairy!
  10. SCFC_Messiah
    SCFC_Messiah Member
    278
    14
    How much of your driving is around the city?
  11. percymon
    percymon Member
    156
    Personally I'd sort the two known faults first. At least you'd eliminate those from any other fault finding.
    900rpm idle would seem about right
  12. paultaylor
    paultaylor Member
    294
    Wouldn't do a huge amount of bumper to bumper city driving.
    About 35-40% urban driving to local shops etc
  13. paultaylor
    paultaylor Member
    294
    Would the G450 sensor fault be contributing to poor mpg?
  14. percymon
    percymon Member
    156
    No idea, but I'd imagine ecu must factor the dpf sensors into its calculations surely, and posisbly revert to a compromise alternative map to bypass fault codes.
    Same with your coolant temp - the ecu will probably use different fuelling if it thinks the engine is cold (assuming the sensor is at fault and not the instrument gauge).
    I'm happy for someone to tell me differently.
    Also many factors affect fuel consumption - driving style, tyres, tyre pressures, etc etc
  15. paultaylor
    paultaylor Member
    294
    I cleaned the two temperature sensor prongs in the coolant last night and the coolant warning didn't come on this morning from a cold start so that is positive.
    Gonna order the G450 dpf sensor and swap it over and adapt and let's see what difference that my have
    thanks
  16. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    My 2.0TFSI petrol Quattro S-Tronic is about 380 miles per tank. 70% 50/60 mph B roads and 30% town driving.
  17. paultaylor
    paultaylor Member
    294
    DIS showed 47.3 mpg on wife's drive from work to home(80% Motorway) seems to be up from 42/43mpg it had been showing lately.
    Is it wishful thinking that cleaning the sensors in the coolant tank and not having the coolant warning light come on from cold start have helped the Mpg?
  18. immo
    immo Stop me
    275
    40
    47mpg on motorways is good. I usually get more like 43- when doing 70+mph
  19. T8DPR
    T8DPR If Carlsberg Made Audi Drivers...
    853
    153
    43
    there are many factors to take into account with MPG, time of day you do your driving, consistent motorway speed, the route you take
    I was getting between 40-45mpg going to work in a morning, slight incline most of the way and hard-ish acceleration needed to come onto a busy roundabout then a dual carriage way, I now take a different turning to avoid that roundabout altogether, its the same distance and takes the same amount of time but as I can keep a fairly consistent speed on the new route I get a touch over 50mpg now
    my route home the very same way is a slight decline almost all the way and gets me 66mpg without fail, I drive to work before 7am and drive home before 4pm
    as a result, around 570-600 per tank, tho it's a 2.0 tdi140
  20. paultaylor
    paultaylor Member
    294
    Sounds impressive, if I could get 500 miles per tank I'll be happy.
  21. paultaylor
    paultaylor Member
    294
    wife's return trip from work just got 48.3mpg on DIS and she said she was driving quick enough on motorway so that's definitely an improvement.
    Cleaning the sensor in coolant tank has had a real effect
  22. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    Is it wrong that my DIS says I'm getting 66mpg on a 100 mile trip ? 2,0tdi 140 bkd
  23. T8DPR
    853
    153
    43
    not necessarily, like I said in my previous post, driving style plays a part, the roads you use, the amount of traffic, on motorways AND in towns
  24. SCFC_Messiah
    SCFC_Messiah Member
    278
    14
    I dont think 66mpg is possible in a 170, I certainly can't get anywhere near that. Sounds like the 140s are much more economical then?
    Also worth remembering that the on board computer figures aren't always reliable. Generally my DIS under reads my real world consumption by a few MPG. Though I've read some stories of other A3s over reading it. Brim to brim test is best if you want to know exactly what you're getting
  25. Mikemc
    1,024
    37
    True, but I don't think I can go a full tank without putting my tie down
  26. articuno88
    articuno88 Member Audi A3
    33
    Other than what's already been mentioned above, the outside temperature affects the MPG too... when it's colder the MPG drops.
    Oh and... tyre pressure - stating the obvious.
    I'm not sure how much I get from a full tank lately since I fill up randomly when I see 'cheap' diesel prices... hehe. Anyway I log all my fill ups on an App called 'Mileage'.
    According to the DIS I average around 45 MPG and that is pretty much combining all the different driving styles and conditions.
    Also anyone know if using the turbo/boost alot reduces MPG? Can't quite put my finger on this one.
    Edit: The DSGs has lower quoted MPG compared to non DSG models. As is with Quattros.
  27. Richard Peters
    Richard Peters Member
    44
    I've only had my 170 SB DSG for a couple of weeks, it's a 2010.
    DIS says 520 miles range on fill up and first tank driving in D mode I saw about 440 miles and filled up with the DIS saying I had 55 miles remaining.
    Second tank I drove in manual and filled up after 460 miles by which point light had been on a while and DIS said I only had 15 miles remaining.
    I probably do 60%ish of my driving on motorway and the majority of the rest on fairly free flowing A and B roads, and rarely sit in traffic. Although on motorway I find myself sitting in the fast lane and probably at a constant speed that could be more efficient if I dropped back a little, although I certainly don't thrash around when I'm on A roads etc. It's hard to quantify MPG I think as everyone will drive differently.
    I'd have liked to hit 500 miles to a tank with my normal driving style, but hey ho!
  28. I have a remapped and dpf removed 170 quattro and get on average 500 miles to a tank, thats mixed major A road and back lane driving..
    Thats somewhere in the region of 40 mpg... On a long motorway journey I will get 600-650+ to a tank
  29. T8DPR
    853
    153
    43
    not sure there's ever a completely accurate way of measuring it unless you're sure your car's computers are 100% accurate and that when your car says you've travelled an exact mile, you actually have!
    When my car was as low in fuel as I dared to let it get, the trip computer said I'd done 603 miles since filling it up and an indicated 55.3mpg over that 603 miles
    however, When I refilled after this, it topped at 55.86 Litres which is obviously the EXACT amount it used over the 603 miles, which actually works out at 49.07mpg
  30. Sidhu88
    Sidhu88 Active Member
    808
    76
    ur about the same as me. I struggle to reach above 35mpg in town. If i hammer it its always around the 30 mark. The most i've ever seen is a tad under 50 after a motorway journey.
