expansion tank boiling after use
ANDYMC_TQS Aug 25, 2011
  1. ANDYMC_TQS
    ANDYMC_TQS Member
    52
    hi iv searched for hours to find a similar prolem but havent found one yet.
    basically whenever i use my car it drives fine at the temp guage sits nice and steady at 90 as it should and never passes that but when i turn the car off i can hear the water in the expansion tank boiling like a kettle and its obviously very hot there too. i checked the thermostat and that is working perfectly so not the problem,
    i checked the water pump and although it was in perfectly good order i changed it to a new one with a metal impellar.
    i also checked the rad and big hoses for blocks by running a hose through thm but good flow.
    i did find a load of browm sludge in the expansion tank so cleaned that thoroughly
    but once i re-assembled the car the promblem still remains
    does anyone have any ideas they would be greatly apreciated
    andy
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Maybe a faulty seal around the expansion tank?
  3. ANDYMC_TQS
    ANDYMC_TQS Member
    52
    i did find half an oring in the tank actually the size of a 10p but i dont know where its come from or where the other half is
  4. colicabcadam
    colicabcadam Guest
    change the lid of the coolant chamber, chances are it's lost its air tight seal - no pressure = lower boiling point
    with an air tight system, i believe the boiling point of water / coolant is something like 125c
  5. ANDYMC_TQS
    ANDYMC_TQS Member
    52
    ok thank you i will give it a go
  6. colicabcadam
    colicabcadam Guest
    they are only like £5 too
  7. Smokey_clark
    Smokey_clark 12th Gear
    210
    What he said..
