  1. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 Team Akoya TDi saloon
    15,161
    1,121
    An idea I had floating around for some time is moving the tail pipes in behind the bumper and smoothing off the bumper spoiler.
    I'm going to leave the smoothing bit to the body shop and the chopping up of the pipes to the garage but I'm unsure on the shoot.
    Being a diesel, will the shoot cover the back end of the car or the underside?
    Whats your general thoughts on this?
    I might do a photoshop when I get home.
    Here is a random back end pic.
  2. Jason.s
    Jason.s Active Member
    2,879
    348
    Works for the Passats and many other diesels so no reason why it wouldnt work on yours providing you have the tips still pointing down obviously.
  3. ScottD3
    15,161
    1,121
    Keeps the tips pointing down.
    just shorten the pipe between the tips and the back box.
    I wonder if this has been to a A4 before, need to see it before I comit.
  4. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,713
    162
    This was a done on an A8 4.2. someone used a diesel back box with tips pointing down and fitted and blanked off the hole in lower trim. Look smart once it was all done. It was a member over on the tyresmoke forum. This was going back to 2007.
    He had no problems with soot under his car.
  5. aragorn
    18,299
    804
    You'll have a hard job of smoothing that hole successfully given that its unpainted plastic....
  6. ScottD3
    15,161
    1,121
    I'm not doing it. I'm **** at paint work.
    Going to talk to the body shop boys.
  7. Oranoco
    Oranoco Well-Known Member
    3,913
    391
    Not my cup of tea but it works for many cars. My missus Clio has a down swept tailpipe hidden behind teh bumper and doesn't have soot problems. Which I'm amased at as her car only gets washed once in a blue moon. lol
  8. Jason.s
    2,879
    348
    Would look smoother and tidier but the amount of work involved i`d rather just get some straight shiney tips put on like we all do on the petrol cars. Fills the gap better than what yours do now and would look better. Ok not amazing for the exhaust soot all up the back of the car but you could try and find a tip like the Mercedes have which is an oval with a slight lip inside it angled down to direct the smoke to the floor but retaining the straight tip look.
  9. ScottD3
    15,161
    1,121
    Get some DTM tips and fit them upside down? lol
    I'm getting the bumper spryed, so if its not to much more i'll get the hole done.
  10. Foxmeister
    Foxmeister Fired Up!
    1,785
    Its a common VW mod of late, and seen a few do it on Audizine aswell, check those sites for it!
  11. aragorn
    18,299
    804
    Even a professional job is going to be dubious in my mind. As soon as you introduce filler and suchlike to a plastic part like that its just going to forever be cracking up.
  12. ScottD3
    15,161
    1,121
    I'll go hunting.
    If you come across any can you post please?
  13. ScottD3
    15,161
    1,121
    There is other means than just filler surly.
  14. Jason.s
    2,879
    348
    To make it blend in ok you`d probably have to paint the lower section but then the bumper would look odd compared to the skirts and the front bumper which remain black plastic.
  15. ScottD3
    15,161
    1,121
    Keep the lower half black but a matt. It might match the sides but not the front but you don't really notice the front bumper spoiler that much.
  16. Jason.s
    2,879
    348
    Colour wise it might blend in alright but the texture compared to the unpainted plastic you have currently might look odd. From a distance it`ll look alright but anything closer might be a bit iffy.
  17. tdia4
    tdia4 TDIPOWARRR
    613
    Was one thing I hated on my B5 was the exhaust showing, always wanted to do the same thing as what you're planning, the B6 I have now is hidden and it looks so much cleaner.
