Exhaust valve and spark plug broken up ouch! Large port questions
StaceyS3 Jul 29, 2011
  1. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Well it all started with a missfire on cylinders 1 & 3 in which i done the usual (change coilpacks) with no luck
    So next i thought i'd check the plugs which 2,3,4, seemed ok but cylinder 1 was in a sorry state
    Starting to worry now and with plenty of helpful advice from phone calls to bill along the way compression test was the next thing on the list, which produced some worrying results cylinders 1 & 3 had 0 compresson and 2 had 25psi whilst 4 had 60psi at first was a bit sceptical as the car was drivable and these were very low so bought my own compression tester and produced the same results.
    Plans to prep the car for the ring with westy and prawn have now been put aside to remove the head and the results weren't good
    But the amazing thing is that the bores look ok, got a mate round who builds engines for a living and he said that they look ok but bore 1 is slightly glazed couldn't get a photo of it really but this is how the pistons look
    My friend thinks that that head gasket was slightly letting by between cylinders 3 & 4 and one of the headbolts which was between these was slightly rusty/orange? And he said could see water marks in bore 3 and on the gasket?
    Going to be taking the pistons and rods out today and think it is a convienient time to chuck some rods in. :eyebrows:
    My friend will back round sunday with a bore gauge to check the wear in the bores so hopefully wont have to take the block out?
    But all in all cylinder 1 is obvious whats happened but cant work out what caused the low comp on the others
    Help and opinions on cause and large port options would be very appriciated?
  2. StaceyS3
    2,505
    502
    Forgot to add that had been running inlet temps between 40-60 degrees once warmed up and the map was only a base map until i would eventually recieve my bigger ah cooler which convieniently arrived monday (two days after the missifre started) dont know if this will be related in any way but thought it possibly could be?
  3. <tuffty/>
    21,689
    4,121
    That head is cracked by the looks... in the pic with the damaged valve there is what looks like a crack spanning the small gap between the exhaust valves... this is where they normally go... you may need to clean off the carbon a bit with some scotch bright to see for sure but looks like it could have got hot in its past...
    Bad luck if that the case :(
  4. StaceyS3
    2,505
    502
    Since posting have found cracks between the exhaust valves on 3 cylinders but have accepted that this one is now probably scrap?
    Good excuse to now go large port think you will probably see my future head in the making knocking around bills at some point ;)
  5. badger5
    9,556
    2,028
    scrap indeed.
    owch!
    PS.. your head got delivered late yesterday
  6. Broken Byzan
    13,237
    465
    Yep, was fresh out of the engine bay, oil still dripping.LOL
  7. StaceyS3
    2,505
    502
    Cheers bill does it look like it was in ok state?
    Am rather unhappy have since found that the exhaust manifold has got a few cracks in it am pretty much certain that they werent there when it was fitted earlier this year and had covered plenty of miles on Pats car so suspect like tuffy said things have got rather to hot under there?
    Really not sure what to do now as i'm sure an mtm manifold is a fortune £££££? :crying:
    Will post pics up in a bit
  8. Dibdub1
    Dibdub1 Suck.Squeeze.Bang.Blow
    228
    Sorry to hear it! :( Hope you get it all sorted!
  9. badger5
    9,556
    2,028
    was this ever mapped for the MTM kit?
    Head condition I will know more when I can see metal under the oil and smeg which covers it all.
    I will get it stripped down and sit in my degrease tank for a day or so to eat away the smeg.
  10. StaceyS3
    2,505
    502
    It had the map uploaded but he said no point playing with timing etc until got the ait's down as ecu would pull anyway so plan was get the new cooler on and get the map finalised but all went tits up 2 days before the new cooler arrived get the feeling should have gone down a different route and got it sorted rather than waiting for ah?
  11. StaceyS3
    2,505
    502
  12. badger5
    9,556
    2,028
    some head pics.. stripped out the cams off it and followers etc
    Sat in dunk tank for the night to loosen the burnt on oil/smeg etc
    Will see better tomorrow whats what when its looking brighter and newer
  13. badger5
    9,556
    2,028
    what map is on it?
    what boost levels was it running, what injectors when with it etc, had it been on a dyno for setting up and checking etc?
  14. StaceyS3
    2,505
    502
    It was running the map for that kit don't know exactly what it was?
    Kim Collins after loading the map took it out and logged for best part of an hour and said it wasn't worth getting on the dyno until I got temps down?
  15. StaceyS3
    2,505
    502
    Forgot to say was running 1.75 bar spike with 1.55 bar to redline which is what ibwas told to get it at with their map??
  16. badger5
    9,556
    2,028
    running pretty hard then..
    Does your car have wideband and egt?
  17. StaceyS3
    2,505
    502
    It is a bam engine 2002 so pretty sure it has this?
    Sorry but was posting from a iphone earlier so not at it's best?
    Wastegate port looks like it's about to break away :crying:
  18. badger5
    9,556
    2,028
    not good dude
  19. StaceyS3
    2,505
    502
    No not at all very depressed lolHave you heard of any proven methods of repairing cast with that kind of stresses involved I certinally haven't?Ps thanks for the pics
  20. StaceyS3
    2,505
    502
    Sorry was supposed to have gone onto the next line where there's no spaces bloody iPhone!!
  21. badger5
    9,556
    2,028
    it can be done.. but for how long it would last tho... Hmmmm
  22. badger5
    9,556
    2,028
    cleaned up after wash tank submersion and scrubbing/pressure washing
    Some slight damage on Cyl 1 which will clean up with skim and minor fettle by me
    Some interesting (to a 1.8t geek like me) differences in head castings between some heads
    AEB Head of Stacey (off a passat)
    AEB Head of Barks
    AQX smallport 1.8t-sport A3 head
  23. Rosso TT
    Rosso TT Member
    146
    Hey Bill, would valves be interchangeable between small port and large port heads?
    Let's say between APX and AEB?
  24. badger5
    9,556
    2,028
    hmmm, yea but..
    I would need to compare overall lengths and groove positions relative to valve tips to confirm.
  25. Westy
    Westy Well-Known Member
    17,443
    1,105
    Unlucky on this one bud. I know how much you wanted to come to the Ring. I doubt your car will be ready now but maybe you can tag along in a mates car or something.
    This type of engine damage is my worse nightmare especially with the milage I have on mine.
    Great work as always Bill :icon_thumright:
  26. StaceyS3
    2,505
    502
    Cheers mate gonna give it my best shot, pretty much everything is in motion now, it is do able but realisticly probably wont be ready as am also away for two other weekends between now and ring :beerchug:
    Going to be going in my mates tt if mines not ready as his only needs a couple of bits and bobs to get it road worthy
    Cheers again Bill :superman:
  27. StaceyS3
    2,505
    502
    Right have had good news from CR's they have inspected the turbo and theres no damage (PHEW) ;)
    So that will be back with me tommorrow
    And as for the manifold got a quote from Welding Process from Slinden Services, Lloyds approved, Pressure testing for £220 + vat but they guarentee their work for 12 months
    Or after speaking to Kim and finding out he had two manifolds knocking about (which to be honest don't think they will sell anymore turbo conversions that cost more than the cars worth) he was happy to do me an ok price of £450 cash
    So as much of a headache it is i thought ti was a bit of a no brainer as had enough of taking this turbo etc off in a carpark (don't fancy a forth go)!
  28. badger5
    9,556
    2,028
    we will have to review the valves/valve gear
    There is a difference in groove length from valve tip to lower edge of top groove..
    what I believe to be smallport valve is 4.6mm and the AEB ones removed from the head are 6.2mm
  29. Lee172
    Lee172 GT3071
    430
    I was told that to get the vvt working correctly on a aeb head you have to drill a hole through the side of the head, is this true?
  30. badger5
    9,556
    2,028
    not aware of this.. The oil feeds are the same on vvt and non vvt, and all of them have hydraulic tensioners.
    will have a closer look for differences tho.
