Exhaust smells petrol today
nvc Nov 11, 2009
  1. nvc
    nvc Member
    45
    hi there,
    left the engine running today while fixing stuff in the boot, then realised
    there was strong petrol smell from the exhaust. the car was bought from
    main dealer 2 weeks ago, with 16k on the clock.
    Can I ask it is normal? should I take it to the dealer to have a look?
    thanks a lot
  2. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,488
    633
    Enjoy the aroma!
    Was it a particularly cold morning?
  3. warren_S5
    warren_S5 Moderator Moderator VCDS Map User
    7,210
    2,487
    pretty normal I'd say. The overfuelling on a cold morning (under what used to be termed as being 'on choke') will mean unburned fuel will be slung through the system if it's sat at idle.
    I'm sure I read in the manual somewhere that you shouldn't leave it sat too long when warming up unless it visibility is so bad (eg. defrosting windscreen) that it is unsafe to drive it.
  4. nvc
    nvc Member
    45
    Hi thanks for your replies, the engine was warm
    temp dial was in the middle 90 degree and I drove a few miles
    so the engine should run at optimised condition ,
    the smell was so strong gave me a headache , normally I love the smell of petrol. :)
  5. warren_S5
    7,210
    2,487
    Suggest it may be worth getting it checked as if you have a leak or it's significantly over duelling both have associated risks.
