Exhaust smell inside car
audi-a6 Jul 27, 2013
  1. audi-a6
    audi-a6 Active Member
    656
    72
    So, an a6 2.7t (posting here as similar engine to s4 and get more response) so as title says, just lately I've notice a strong smell of exhaust gasses inside car, but only when I put my foot down and on boost, if just pooling along at any speed at any rev it's fine, no smell at all, but as soon as on boost, it stinks inside car, I've checked under car, no exhaust blowing or any thing like that, any ideas?
    i might have lost a bot of power as well, as don't seem as torquey as it was but might just be I've got so used to the car
  2. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Has the Pollen filter been changed?
  3. Chillout
    Chillout Active Member
    609
    50
    Try and restrict the exhaust with a rag and have someone look under the bonnet and chassis for leaks
  4. shady-ninja
    shady-ninja Active Member
    999
    53
    charcoal filter??
  5. audi-a6
    656
    72
    No the pollen filter has not been changed, but still the shouldn't be any gasses in the engine bay.
    does my car have a charcoal filter?
    with rags, worth ago I suppose
  6. audi-a6
    656
    72
    so, bunged up the tail pipes and no blows what so ever, so it must be between turbos and inlet manifold?
  7. audi-a6
    656
    72
    anyone got any ideas?
  8. audi-a6
    656
    72
    one thing i have noticed is that when the engine is cold, the smell is constant and only when the engine is warmed up is when it only smells under power load
  9. Sulli79
    Sulli79 Active Member
    541
    37
    Maybe a cracked manifold or turbine housing if your sure its not gaskets
  10. audi-a6
    656
    72
    would i not hear it though?
  11. audi-a6
    656
    72
    and it seems weird that when you first start car, you can smell the fumes on both sides at the back of the engine, (when your under the bonnet)
  12. Sulli79
    541
    37
    You may not hear it, both your turbos should be near the back on either side, you may be lucky and it's just gaskets
  13. Todd1983
    Todd1983 Member
    147
    I had similar and was turbo-downpipe gaskets, but I could hear the leak
  14. audi-a6
    656
    72
    would that cause power loss?
  15. Sulli79
    541
    37
    Between manifold and turbo it will because less gasses to spin the turbine, and turbo to down pipe may see a minor drop due to loss of back pressure
